Vodafone Easybox 805
AkashAntony
Hi Team,
I recently made a switch from Vodafone DSL to Telekom Glasfaser. I am using the Easybox 805 as my router. Could you please provide me the method i could use to activate my router for Telekom.
I am not able to receive any internet and it is affecting my work. Please help urgently.
Regards,
Akash Antony
9 Antworten 9
RobertP
buy a router that is compatible with your Telekom fiber optic connection
the Easybox 805 has no WAN port which is nessesary to connect the router to the ONT
We have a modem to connect to the easybox. the modem is connected to the Glass fiber. How do i change the connection in Easybox?
again, the Easybox 805 does not have a WAN port, therefore it is not possible to conect it to the Modem/ONT (Optical Network Termination)
Hi Robert, The EasyBox 805 i see has a WAN port. Do i connect my Modem to WAN port?
then try to connect it to the ONT/Modem
maybe I have confused 805 with the previous model and the WAN port of the 805 is usable
I have connect it to Modem and it turns green. but I am not getting Internet connection. Do i need to reset my router?
you need to change router settings
in standard configuration the Easybox uses DSL port to connect to the internet and you have to reconfigure for using WAN port to establish the connection
Hi Robert,
How is that done?
I have neihter an Easybox 805 nor fiber optic connection
https://www.vodafone.de/downloadarea/bedienungsanleitung-easybox-805.pdf
