Steam throttling 10Mbps
JohnnyNice
Hello
It seems that Vodafone intentionally throttles my connections to Steam downloads as well as to any VPN with L2TP, PPTP and OpenVPN to 10 Mbps. What's the point of having a 1-Gbit/s cable connection when what is most important to me is throttled to a ***ty speed? Please remove the throttling. Thank you very much.
Edit: Thread in passendes Board verschoben. Lars
Moni_GK
Hello JohnnyNice,
we do not throttle speeds to providers. What does the speedtest say?
Greetings Moni
I see throttling whenever I try to download from Steam servers. No matter what server I choose, the connection will not go above 10Mbps. I do not care what speedtest.net says, because you are obviously throttling some port. Trying the same connection to steam servers using 4G Vodafone works fine at nearly 100Mbps, which means you are throttling, since even servers from other providers like Microsoft are working fine. The same problem happens when I connect to any VPN, even the one at work that has 1Tbps. So what the heck. Stop throttling me. Thanks.
Hello JohnnyNice,
please answer the questions from this thread: https://forum.vodafone.de/t5/St%C3%B6rungsmeldungen-Internet-TV/Kabel-Alles-rund-um-St%C3%B6rungsmel...
Regards
