Pushpage.arcor.de/wrongaccount error!
KonstantinK1
Good afternoon,
Apologies, I don't speak German well. I have a problem. After the technician visit, my internet connection was set (fritz box shows internet is connected), but I can only open google.com and google web-services (mailbox). All the other web-sites don't work and I have pushpage.arcor.de error. Can someone help please? I read some topics, seems like can be fixed by vodafone
Thank you
Best regards,
Konstantin
Edit: Thread moved to DSL board.
2 Antworten 2
Norman
Community Manager
Community Manager
Do not worry. We also help in English. 😉
The bug sounds strange. The page is displayed if the commercial activation is not completed or there are still outstanding invoices.
It is probably due to the activation. Sometimes it takes a while until the connection can be used after the technician's visit. Did you set up the router with the modem installation code?
If so, is it working now? If not, please send me a private message with your customer number. It starts with 0019. I'll take a look.
Best wishes
Norman
Thank you Norman.
Yes, I used installation code from the contract and according to fritzbox settings everything is working.
I've sent you PM with some screenshots as well, I'll apreciate if you can have a look asap into this problem.
Many thanks in advance.
Best regards,
Konstantin
