Vodafone Tariff Change
Karthi1303
I am currently using   Red Internet & Phone 1000 Cable  for the past 2 months and my contract ends on 01/27/2023. I would like to change the tariff, but I have a few questions.
if I change my tariff within the first 6 months ie before 7/27/2021
1) Will my Contract end date remains the same  ie 01/27/2023 or a new 24 months will add up ??
2) The changing of tariff is after 6 months or immediately ??
Regards
Karthick
Edit @Karthi1303 You are using a cable contract. Switched to the correct board. BR, DanyG
6 Antworten 6
DanyG
Hi Karthi1303,
welcome to the Vodafone community. Smiley (fröhlich)
Can you please let us know, in which federal state you are using your cable connection?
BR,
Dany
Hi Dany,
I am currently living in Bavaria.
My contract starts 2 months before (January 2021), so I would like to know how tariff changing works. I don't want to extend the contract by more than 24 months.
Looking for your support.
Grit
Hello Karthi1303
you have received an order confirmation. It lists what you need to do to switch to a lower rate after the first 6 months. The conditions are also listed there.
Regards
Grit
Hello Grit,
As per the contract, it said
You can switch until the end of the 6th month free of charge to the following Red Internet & Phone Cable rates: 500 for 44.99 € / month, 250 for 39.99 € / month, 100 for 34.99 € / month or 50 for 29.99 € / month . The change takes place on the 7th month. This does not change your minimum contract term.
It says the minimum contract term does not change if it's TRUE then I would like to switch to a lower tariff now itself.
Regards
Karthick
To which tariff do you want to change? Moderators can do it, but you need to say which option you want to take.
Grit
Hello Karthi1303
well, let's do that. Also let me know which tariff you want.
Regards
Grit
