44158 Port forwarding problem
adsahin01
Hello.
I have Vodafone Station and kabel internet.
TCP port 44158 is closed in my internet.
How can I open this port? I want to forward 44158 to the local IP address:
Best regards,
Adnan Sahin
Torsten
If your connection is connected via IPv6 with a DS-lite tunnel, like all new private customer connections, there is no port forwarding. Then you can only create IPv6 shares.
FROO
U got a solution for this one?
What federal state are you from?
At VFW (North Rhine-Westphalia, Baden-Württemberg, Hesse) there is the option of adding the Power Upload option to the Red Internet&Phone 250 and 500 Cable tariffs for €2.99/month and then switching to native dual stack via customer service apply for.
With VFD (remaining federal states), either the Vodafone station can be operated in bridge mode with its own router behind it with IPv4 only, or you can use your own cable router (e.g. a Fritzbox Cable) and then choose for yourself whether you want IPv4 only, IPv6 only, want to use IPv6 with DS lite or Dual Stack.
