Wi-Fi Analyser 5GHz
medicol
App-Professor
App-Professor
Modem router from Vodafone using Wi-Fi Analyser 5GHz reports graph of 2.6 GHz channels.
I keep 2.6 GHz WLAN off
Firmware version: AR01.05.063.15_082825_735.PC20.20.VF
Hardware Type & Version: 9
Open Source Firmware version:          01.05.063.15.EURO.PC20
Will you correct the bug ?
Beiträge zum selben Thema zusammengefasst!
7 Antworten 7
medicol
App-Professor
App-Professor
If I set WiFi bandwidth 160 MHz and Auto at Vodafone Station then there WiFi no more come up
why?
I forgot, I have TG6442VF
Thanks for your message!
Just as a quick note: the Vodafone Community is a customers‑help‑customers forum, so nobody here can access firmware systems or trigger fixes for device bugs.
If you want this issue to be checked by us, you need to contact our support team. They can open a technical ticket and forward the bug to the responsible unit.
You can reach Vodafone directly via WhatsApp: https://vod.af/VodafoneWhatsAppHilfe
thank you Emily, sure Community cannot solve but maybe someone had same problem and found workaround or simply tell me if I did something wrong. Moreover I noticed that TG6442VF can set manually WiFi channel to be used, but channel available are only the ones 20 MHz bandwidth deputy. So if I want to fix a 80 MHz channel (e.g. 42 or 58) I cannot. What should I insert?
Hi @medicol :).
What exactly do you mean by that? Could you please be a bit more precice?
BR
RED_DUSTin
if I set bandwidth = 80 MHz then I can set manually the following channels: 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124 128.
From WiFi specification, 80 MHz channels are the following: 42, 58, 106,122.
What should I choose? The only available channels that can be set are the ones that WiFi specifications define as 20 MHz bandwidths
medicol
App-Professor
App-Professor
