DOCSIS Offline
Anca29
Hello,
Since 2 days ago I have problems with my internet connection, it worked fine for 3 years.
I have restarted the router and also reset it few times, but the INTERNET LED on it still stays RED and is blinking.
If I´m connecting on the router looks like DOCSIS is offline.
I also have unplugged/plugged the cables but nothing is solved.
Can someone help on this? Should I provide more information?
Thank you 🙂
Anca
Chr1ssy
Hi @Anca29,
I'm sorry your connection isn't working as it should be.
We would be very happy to help you. Therefore we need another message from you on one of the following channels.
Best regards
Chr1ssy
