Easybox804 Stuck on Insert DSL cable
easybox804issue
Hello Team,
I have recently changed my connection from low speed to high speed . Its from 16mbpsto 25 mbps on Friday.
I have been told that i can use same modem Easybox804 for the new connection.
I Have MIC for modem activation but while doing activation I am getting on page that shows me error like  " Connect DSL cable in DSL port on modem and start." But Cable is already conected but still I am not able to see "Continue " button active, its still gray inactive.
Several times I did reset and factory reset but it got stuck at same page.
I can see Powe r-Red LED at bottom and only one LED green on top that is for WLAN , rest all EDs are not glowing?
Please guide me s it connection problem or Modem problem?
Please guide me on this topic , SInce I am not able to speak German so I am not able to get support from team.
Please help.
Sachin Jadhav
Jens-K
Hi Sachin,
welcome to the Vodafone Community!
Please check if you are using the correct MIC. You should have received a new one for the new DSL connection.
If you still can not activate your modem, send me a private message. I will have a look into this.
I need your name, your customer number and your mobile phone number.
Regards,
Jens
