internet connect is not stable
woo
the internet connection is too unstable.
everyday, the internet did not connect during a few hours and re-connected a few hours.
this situation repeat everyday. when internet is not connecting, the lights of the router just blinking.
sometime, the internet did not work for a whole day.
I have had contact with vodafone custumer center several times and they just said there was no problem.
so i try to wait just solved. but it has not been solved from last 6 month
18 Antworten 18
Hello woo,
I'd like to check your connection, please send me a private message that includes your address, customer number and date of birth. Answer here again after you sent the PM.
Kind regards
woo
hallo, claudia,
I sent the email about my infor you requested.
thanks
Hello woo,
your modem is offline at the moment, but other modems in the building are not, although they have a bad signal. So I would like to send a technician that checks the line and replaces the modem, if necessary. May I forward the telephone number that ends on ***515 so he can call you to make an appointment with you?
Kind regards,
woo
yes. please.
and it could better, the technicain can speak english.
pRo-Marco
Hi woo,
your modem is online again. Does it work now? The signal seems to be okay.
A technician is not needed at the moment.
Kind regards
woo
as i told you, the internet just keeps on and off every day.
even i didn't do anything.
for now, it is not working.
please keep monitoring and solve this problem.
Jens
Hello woo,
at the moment, the connection is also online.
Did you use a timeswitch for the cable-router or the socket?
If we instruct a technician and he find out, that the problem is your fault, it cost 99,50€. Only he find out, that's our problem, it's free for you.
Regards
Jens
woo
no, i didn't use any timeswitch.
if a technician find out it is your fault, can i pay back for time internet didn't work?
and i just worry about when a technicain come to check my internet, the internet work well and he just say there are no problem. but after he will leave the internet don't work again.
i jsut want to make sure, a technician check everything, even the internet is work at the time he come here.
woo
and for now.
in router configure page.
the router status is operational, but internet does not have any signal.
