Static IP / Reverse DNS
evghenix
Hello,
I would like to reserve a Static IP and cofigure reverse DNS for me, could you please help with that?
Best regards,
Eugeniu
6 Antworten 6
Gelöschter User
Nicht anwendbar
Do you have a business account?
You can't do it with a private account.
If you have a business account -AND- the option "Feste IP-Adresse" (Static IP address), there should be corresponding settings in your customer self-service portal.
Anyhow there are two limitations:
You'll need to add TXT records to your domain so that Vodafone can check that you are the owner
-and-
You can only set PTR records for the first 5 IPv6 addresses (::1 .. ::5) from the first subnet of your /56 block.
No, I have personal account. Reverse DNS is not so important to me, but I vould like to have a satic IP
Hello evghenix,
as reneromann wrote, you can get the option Feste IP with a business contract.
Kind regards,
Gelöschter User
Nicht anwendbar
do you really need a static ip? This is only available in business.
Maybe you like to have DS instead of DS-Lite?
Please remember, ipv4 do not change very often. My last change was at 2020-12-03 in a private account
Yes, it's changed not often but still it is changing time to time. Ok, that you all for the answers.
