Router question (English)
miladinkata
I am using cable internet 2PLY FLY 400 and router VODAFONE TG3442DE.
Router coverage is very small and i decided to switch the router but when i decided which one i want to buy i saw the difference in inputs/outputs, there is no "cable" hole in new router. Is it possible to use my own router purchased from technic store or not. Router which i want to use is Asus GT-AX11000.
Asus router inputs in attachment
Stephan
Hi miladinkata,
you can't use this router directly with the cable socket.
For further questions regarding your Unitymedia contract, please use the following contact channels:
Facebook: https://www.facebook.com/UnitymediaHilfe
Twitter: https://www.twitter.com/UnitymediaHilfe
WhatsApp: https://api.whatsapp.com/send?phone=4917688866310
(Dieser Link öffnet WhatsApp auf Deinem Smartphone und Du bist direkt im Dialog mit Unitymedia Hilfe)
Community: https://community.unitymedia.de
Regards
Stephan
