Cable connection available but local partner denies installation
Luis_Fellbach
Hello,
Sorry to write in english but is the way I can make the problem clearer.
I live in the Cannstatterstr. ***/1 in Fellbach (70734), in a 2017 newly built housing complex with 6 buildings.
It happens that all buildings are connected to the internet via building ***, meaning that all cables from the street comes to number ***and all the houses are connected to this "technikraum".
Due to this technical constelation, address *** is marked as not available. As my neighbours did, I gave address *** for the installation but the local partner S30 denies intallation as this is not the address where I live.
Can you please support me on making the address *** available?
Edited personal data / LG, Su
Stephan
Hi Luis_Fellbach,
welcome to our Community.
Since this address is in the distribution area of Unitymedia, I would like to ask you to contact the colleagues of Unitymedia.
Unfortunately we can't help you here and so I have to close this thread.
Regards
Stephan
Stephan
Hi Luis_Fellbach,
Regards
Stephan
