Ständige Verbindungsabbrüche
JoLemPL
Hallo ich bin Kabel Kunde und habe ständige Verbindungsabbrüche und sehe diese Meldungen in meinem erreignisprotokol:
 02/26/2021 11:15:07 UTOPIA: FW.IPv6 FORWARD drop Firewall
02/26/2021 11:15:07 UTOPIA: FW.IPv6 INPUT drop Firewall
02/26/2021 11:15:07 UTOPIA: IPv6 Blocked DROP Firewall
02/26/2021 11:15:06 UTOPIA: FW.LANATTACK DROP Firewall
02/26/2021 11:15:06 UTOPIA: FW.WANATTACK DROP Firewall
02/26/2021 11:15:06 UTOPIA: IPv4 Blocked DROP Firewall
02/26/2021 11:15:04 UTOPIA: FW.IPv6 FORWARD drop Firewall
02/26/2021 11:15:04 UTOPIA: FW.IPv6 INPUT drop Firewall
02/26/2021 11:15:04 UTOPIA: IPv6 Blocked DROP Firewall
02/26/2021 11:15:03 UTOPIA: FW.LANATTACK DROP Firewall
02/26/2021 11:15:03 UTOPIA: FW.WANATTACK DROP Firewall
02/26/2021 11:15:03 UTOPIA: IPv4 Blocked DROP Firewall
02/26/2021 11:15:00 UTOPIA: FW.IPv6 FORWARD drop Firewall
02/26/2021 11:15:00 UTOPIA: FW.IPv6 INPUT drop Firewall
02/26/2021 11:15:00 UTOPIA: IPv6 Blocked DROP Firewall
02/26/2021 11:14:59 UTOPIA: FW.LANATTACK DROP Firewall
02/26/2021 11:14:59 UTOPIA: FW.WANATTACK DROP Firewall
02/26/2021 11:14:58 UTOPIA: IPv4 Blocked DROP Firewall
02/26/2021 11:14:54 UTOPIA: IPv6 Blocked DROP Firewall
02/26/2021 11:14:52 UTOPIA: FW.LANATTACK DROP Firewall
02/26/2021 11:14:52 UTOPIA: FW.WANATTACK DROP Firewall
02/26/2021 11:14:51 UTOPIA: IPv4 Blocked DROP Firewall
02/26/2021 11:14:48 UTOPIA: FW.LANATTACK DROP Firewall
02/26/2021 11:14:48 UTOPIA: FW.WANATTACK DROP Firewall
02/26/2021 11:14:48 UTOPIA: IPv6 Blocked DROP Firewall
02/26/2021 11:14:47 UTOPIA: IPv4 Blocked DROP Firewall
02/26/2021 11:13:23 UTOPIA: FW.IPv6 FORWARD drop Firewall
02/26/2021 11:13:23 UTOPIA: FW.IPv6 INPUT drop Firewall
02/26/2021 11:13:23 UTOPIA: IPv6 Blocked DROP Firewall
02/26/2021 11:13:22 UTOPIA: FW.LANATTACK DROP Firewall
02/26/2021 11:13:22 UTOPIA: FW.WANATTACK DROP Firewall
02/26/2021 11:13:22 UTOPIA: IPv4 Blocked DROP Firewall
02/26/2021 11:12:21 UTOPIA: FW.IPv6 FORWARD drop Firewall
02/26/2021 11:12:21 UTOPIA: FW.IPv6 INPUT drop Firewall
02/26/2021 11:12:21 UTOPIA: IPv6 Blocked DROP Firewall
02/26/2021 11:12:19 UTOPIA: FW.LANATTACK DROP Firewall
02/26/2021 11:12:19 UTOPIA: FW.WANATTACK DROP Firewall
02/26/2021 11:12:18 UTOPIA: IPv4 Blocked DROP Firewall
02/26/2021 11:12:15 UTOPIA: FW.IPv6 FORWARD drop Firewall
02/26/2021 11:12:15 UTOPIA: FW.IPv6 INPUT drop Firewall
02/26/2021 11:12:15 UTOPIA: IPv6 Blocked DROP Firewall
02/26/2021 11:12:14 UTOPIA: FW.LANATTACK DROP Firewall
02/26/2021 11:12:14 UTOPIA: FW.WANATTACK DROP Firewall
02/26/2021 11:12:13 UTOPIA: IPv4 Blocked DROP Firewall
02/26/2021 11:12:11 UTOPIA: FW.IPv6 FORWARD drop Firewall
02/26/2021 11:12:11 UTOPIA: FW.IPv6 INPUT drop Firewall
02/26/2021 11:12:11 UTOPIA: IPv6 Blocked DROP Firewall
02/26/2021 11:12:10 UTOPIA: FW.LANATTACK DROP Firewall
02/26/2021 11:12:10 UTOPIA: FW.WANATTACK DROP Firewall
02/26/2021 11:12:09 UTOPIA: IPv4 Blocked DROP Firewall
02/26/2021 11:16:20 [88000301]: Configuration Changed. ACS Setting Channel = 13. WLAN
02/26/2021 11:16:20 [88000301]: Configuration Changed. ACS Setting Channel = 40. WLAN
02/26/2021 11:16:17 [88000301]: Associated Device 9A:DA:C4:00:00:00 Bytes Sent=98450361;Bytes Recieved=776. WLAN
02/26/2021 11:16:17 [88000301]: Associated Device 9A:DA:C4:00:00:00 Error Count=0;Tx Retry Count=0. WLAN 02/26/2021 11:16:17 [88000301]: Associated Device 9A:DA:C4:00:00:00 Packets Sent=2;Packets Recieved=2. WLAN
02/26/2021 11:16:17 [88000301]: Associated Device 9A:DA:C4:00:00:00 Supported 802.11 Standards =ac;RSSI =-46. WLAN
02/26/2021 11:16:17 [88000101]: Device 9A:DA:C4:00:00:00 Associated to 5GHz. WLAN
02/26/2021 11:16:17 [88000101]: Device 9A:DA:C4:00:00:00 Associated with Security WPA + WPA2 WLAN 02/26/2021 11:16:17 [88000101]: Device Associated.WG-MAC=9A:DA:C4:00:00:00;SSID="Wu;On Channel=40. WLAN
02/26/2021 11:16:17 [88000301]: Associated Device 9A:DA:C4:00:00:00 Bytes Sent=98463421;Bytes Recieved=19378. WLAN
02/26/2021 11:16:17 [88000301]: Associated Device 9A:DA:C4:00:00:00 Error Count=0;Tx Retry Count=0. WLAN 02/26/2021 11:16:17 [88000301]: Associated Device 9A:DA:C4:00:00:00 Packets Sent=3;Packets Recieved=6. WLAN
02/26/2021 11:16:17 [88000301]: Associated Device 9A:DA:C4:00:00:00 Supported 802.11 Standards =ac;RSSI =-48. WLAN
02/26/2021 11:16:15 [88000301]: Configuration Changed. ACS Setting Channel = 13. WLAN
02/26/2021 11:16:15 [88000301]: Configuration Changed. ACS Setting Channel = 40. WLAN
02/26/2021 11:14:08 [88000301]: Associated Device 9A:DA:C4:00:00:00 Bytes Sent=98410781;Bytes Recieved=308. WLAN
02/26/2021 11:14:08 [88000301]: Associated Device 9A:DA:C4:00:00:00 Error Count=0;Tx Retry Count=0. WLAN 02/26/2021 11:14:08 [88000301]: Associated Device 9A:DA:C4:00:00:00 Packets Sent=2;Packets Recieved=2. WLAN
02/26/2021 11:14:08 [88000301]: Associated Device 9A:DA:C4:00:00:00 Supported 802.11 Standards =ac;RSSI =-44. WLAN
02/26/2021 11:14:08 [88000101]: Device 9A:DA:C4:00:00:00 Associated to 5GHz. WLAN
02/26/2021 11:14:08 [88000101]: Device 9A:DA:C4:00:00:00 Associated with Security WPA + WPA2 WLAN 02/26/2021 11:14:08 [88000101]: Device Associated.WG-MAC=9A:DA:C4:00:00:00;SSID="Wu;On Channel=40. WLAN
02/26/2021 11:14:08 [88000301]: Associated Device 9A:DA:C4:00:00:00 Bytes Sent=98410849;Bytes Recieved=1278. WLAN
02/26/2021 11:14:08 [88000301]: Associated Device 9A:DA:C4:00:00:00 Error Count=0;Tx Retry Count=0. WLAN 02/26/2021 11:14:08 [88000301]: Associated Device 9A:DA:C4:00:00:00 Packets Sent=3;Packets Recieved=6. WLAN
02/26/2021 11:14:08 [88000301]: Associated Device 9A:DA:C4:00:00:00 Supported 802.11 Standards =ac;RSSI =-42. WLAN 02/26/2021 11:14:08 [88000101]: Device 9A:DA:C4:00:00:00 Associated to 5GHz. WLAN 02/26/2021 11:14:08 [88000101]: Device 9A:DA:C4:00:00:00 Associated with Security WPA + WPA2 WLAN 02/26/2021 11:14:08 [88000101]: Device Associated.WG-MAC=9A:DA:C4:00:00:00;SSID="Wu;On Channel=40. WLAN
02/26/2021 11:14:07 [88000301]: Associated Device 9A:DA:C4:00:00:00 Bytes Sent=98410849;Bytes Recieved=1278. WLAN
02/26/2021 11:14:07 [88000301]: Associated Device 9A:DA:C4:00:00:00 Error Count=0;Tx Retry Count=0. WLAN 02/26/2021 11:14:07 [88000301]: Associated Device 9A:DA:C4:00:00:00 Packets Sent=30;Packets Recieved=30. WLAN
02/26/2021 11:14:07 [88000301]: Associated Device 9A:DA:C4:00:00:00 Supported 802.11 Standards =ac;RSSI =-42. WLAN
02/26/2021 11:14:07 [88000101]: Device 9A:DA:C4:00:00:00 Associated to 5GHz. WLAN
02/26/2021 11:14:07 [88000101]: Device 9A:DA:C4:00:00:00 Associated with Security WPA + WPA2 WLAN 02/26/2021 11:14:07 [88000101]: Device Associated.WG-MAC=9A:DA:C4:00:00:00;SSID="Wu;On Channel=40. WLAN
02/26/2021 11:13:57 [88000205]: Interface Reset ,Link is Up. WLAN
02/26/2021 11:13:56 [88000301]: Configuration Changed. ACS Setting Channel = 13. WLAN
02/26/2021 11:13:56 [88000301]: Configuration Changed. ACS Setting Channel = 40. WLAN
02/26/2021 11:13:46 [88000102]: Device disconnected 9A:DA:C4:00:00:00 REASON-CODE=8. WLAN 02/26/2021 11:13:46 [88000301]: Associated Device 9A:DA:C4:00:00:00 Bytes Sent=0;Bytes Recieved=0. WLAN 02/26/2021 11:13:46 [88000301]: Associated Device 9A:DA:C4:00:00:00 Error Count=0;Tx Retry Count=0. WLAN 02/26/2021 11:13:46 [88000301]: Associated Device 9A:DA:C4:00:00:00 Packets Sent=3;Packets Recieved=12. WLAN
02/26/2021 11:13:46 [88000301]: Associated Device 9A:DA:C4:00:00:00 Supported 802.11 Standards =a;RSSI =0. WLAN
02/26/2021 11:13:46 [88000101]: Device 9A:DA:C4:00:00:00 Associated to 5GHz. WLAN 02/26/2021 11:13:46 [88000101]: Device 9A:DA:C4:00:00:00 Associated with Security WPA + WPA2 WLAN 02/26/2021 11:13:46 [88000101]: Device Associated.WG-MAC=9A:DA:C4:00:00:00;SSID="Wu;On Channel=40. WLAN 02/26/2021 11:13:46 [88000301]: Associated Device 9A:DA:C4:00:00:00 Bytes Sent=98411301;Bytes Recieved=4262. WLAN 02/26/2021 11:13:46 [88000301]: Associated Device 9A:DA:C4:00:00:00 Error Count=0;Tx Retry Count=0. WLAN 02/26/2021 11:13:46 [88000301]: Associated Device 9A:DA:C4:00:00:00 Packets Sent=3;Packets Recieved=6. WLAN
02/26/2021 11:13:46 [88000301]: Associated Device 9A:DA:C4:00:00:00 Supported 802.11 Standards =ac;RSSI =-48. WLAN
02/26/2021 11:13:38 [88000301]: Associated Device 9A:DA:C4:00:00:00 Bytes Sent=98408655;Bytes Recieved=18769. WLAN
02/26/2021 11:13:38 [88000301]: Associated Device 9A:DA:C4:00:00:00 Error Count=0;Tx Retry Count=0. WLAN 02/26/2021 11:13:38 [88000301]: Associated Device 9A:DA:C4:00:00:00 Packets Sent=3;Packets Recieved=12. WLAN
02/26/2021 11:13:38 [88000301]: Associated Device 9A:DA:C4:00:00:00 Supported 802.11 Standards =ac;RSSI =-48. WLAN 02/26/2021 11:13:38 [88000101]: Device 9A:DA:C4:00:00:00 Associated to 5GHz. WLAN 02/26/2021 11:13:38 [88000101]: Device 9A:DA:C4:00:00:00 Associated with Security WPA + WPA2 WLAN 02/26/2021 11:13:38 [88000101]: Device Associated.WG-MAC=9A:DA:C4:00:00:00;SSID="Wu;On Channel=40. WLAN
02/26/2021 11:13:38 [88000301]: Associated Device 9A:DA:C4:00:00:00 Bytes Sent=98408641;Bytes Recieved=2930. WLAN
02/26/2021 11:13:38 [88000301]: Associated Device 9A:DA:C4:00:00:00 Error Count=0;Tx Retry Count=0. WLAN 02/26/2021 11:13:38 [88000301]: Associated Device 9A:DA:C4:00:00:00 Packets Sent=3;Packets Recieved=6. WLAN
02/26/2021 11:13:28 [88000301]: Associated Device 9A:DA:C4:00:00:00 Bytes Sent=98394995;Bytes Recieved=2021. WLAN
02/26/2021 11:13:28 [88000301]: Associated Device 9A:DA:C4:00:00:00 Error Count=0;Tx Retry Count=0. WLAN 02/26/2021 11:13:28 [88000301]: Associated Device 9A:DA:C4:00:00:00 Packets Sent=3;Packets Recieved=12. WLAN
02/26/2021 11:13:28 [88000301]: Associated Device 9A:DA:C4:00:00:00 Supported 802.11 Standards =ac;RSSI =-50. WLAN 02/26/2021 11:13:28 [88000101]: Device 9A:DA:C4:00:00:00 Associated to 5GHz. WLAN 02/26/2021 11:13:28 [88000101]: Device 9A:DA:C4:00:00:00 Associated with Security WPA + WPA2 WLAN 02/26/2021 11:13:28 [88000101]: Device Associated.WG-MAC=9A:DA:C4:00:00:00;SSID="Wu;On Channel=40. WLAN
02/26/2021 11:13:28 [88000301]: Associated Device 9A:DA:C4:00:00:00 Bytes Sent=98394969;Bytes Recieved=1278. WLAN
02/26/2021 11:13:28 [88000301]: Associated Device 9A:DA:C4:00:00:00 Error Count=0;Tx Retry Count=0. WLAN 02/26/2021 11:13:28 [88000301]: Associated Device 9A:DA:C4:00:00:00 Packets Sent=3;Packets Recieved=6. WLAN
02/26/2021 11:13:28 [88000301]: Associated Device 9A:DA:C4:00:00:00 Supported 802.11 Standards =ac;RSSI =-43. WLAN
02/26/2021 11:13:27 [88000301]: Configuration Changed. ACS Setting Channel = 13. WLAN
02/26/2021 11:13:27 [88000301]: Configuration Changed. ACS Setting Channel = 40. WLAN
02/26/2021 11:13:26 [88000301]: Configuration Changed. ACS Setting Channel = 13. WLAN
02/26/2021 11:13:26 [88000301]: Configuration Changed. ACS Setting Channel = 40. WLAN
02/26/2021 11:13:24 [88000101]: Device 9A:DA:C4:00:00:00 Associated with Security WPA + WPA2 WLAN 02/26/2021 11:13:24 [88000101]: Device Associated.WG-MAC=9A:DA:C4:00:00:00;SSID="Wu;On Channel=40. WLAN
02/26/2021 11:13:24 [88000301]: Associated Device 9A:DA:C4:00:00:00 Bytes Sent=98392339;Bytes Recieved=1278. WLAN
02/26/2021 11:13:24 [88000301]: Associated Device 9A:DA:C4:00:00:00 Error Count=0;Tx Retry Count=0. WLAN 02/26/2021 11:13:24 [88000301]: Associated Device 9A:DA:C4:00:00:00 Packets Sent=3;Packets Recieved=6. WLAN
02/26/2021 11:13:24 [88000301]: Associated Device 9A:DA:C4:00:00:00 Supported 802.11 Standards =ac;RSSI =-43. WLAN
02/26/2021 11:13:24 [88000101]: Device 9A:DA:C4:00:00:00 Associated to 5GHz. WLAN
Das Device 9A:DA:C4:00:00:00 ist ein TP-Link repeater aber das problem ist auch da wenn dieser nicht in benutzung ist
Screenshot 2021-02-26 125420.pngScreenshot 2021-02-26 125452.pngScreenshot 2021-02-26 125516.pngScreenshot 2021-02-26 125537.png
7 Antworten 7
Hallo JoLemPL,
hattest Du dazu bereits Kontakt zur Störungshotline? Welche Software ist auf dem Router drauf? Hast Du ihn bereits zurückgesetzt? Kommt es jedes Mal zum Abbruch, wenn im Routerlog ein Eintrag auftaucht? Wie sieht es über LAN aus?
F: hattest Du dazu bereits Kontakt zur Störungshotline?
A: noch nicht
F:Welche Software ist auf dem Router drauf?
A: Firmware-Version 2.0.17-IMS-KDG
F:Hast Du ihn bereits zurückgesetzt?
A: ja
F:Kommt es jedes Mal zum Abbruch, wenn im Routerlog ein Eintrag auftaucht?
A: ja
F:Wie sieht es über LAN aus?
A:Es pasier meistens wenn ich am PC bin der Über LAN verbunden ist
pRo-Marco
Hi JoLemPL,
wir schauen uns das einmal an. Schicke mir bitte eine PN mit Deinem Namen, der Anschrift, Dein Geburtsdatum und Deiner Kundennummer und sag mir kurz hier Bescheid, wenn Du die Nachricht versendet hast.
Habe die PN gesendet
pRo-Marco
Hi JoLemPL,
das Modem wechselt sehr oft die Frequenz und die Pegel schwanken. Schaut mir nach nem defekten Verstärker aus.
Ich möchte gern einen Techniker beauftragen, der sich das vor Ort anschaut. Wenn das für Dich in Ordnung ist, dann brauche ich noch eine Handynummer, damit wir einen Termin vereinbaren können.
Ist die Hausanlage zugänglich?
Aufgrund der aktuellen Entwicklungen müssen wir gewisse Vorsichtsmaßnahmen treffen. Daher müssen wir wissen, ob in Deinem Haushalt Symptome aufgetreten sind, die im Zusammenhang mit Covid-19 stehen könnten. Wir wollen Dir natürlich nicht zu nahe treten, aber andererseits wollen wir auch nicht unnötig noch mehr Menschen gefährden.
Habe die nummer als PN gesendet .
pRo-Marco
Hi JoLemPL,
der Techniker ist beauftragt und ruft Dich noch an, um einen Termin auszumachen.
