Modem/Router defekt
Walrus
Hi, I have cable Internet contract since 2015 (when it was Kabel Deutchland). Recently upgrade my contract to
a download speed of 200 Mbit/s. Unfortunately the cable modem is not providing high speed with WLAN.
Using LAN the speed is OK-ish between 150-180 Mbit/s, but measuring over the same computer/ same browser/ same time the max speed on WLAN is 50 Mbit/s. Measurments were done at 30cm from the modem, and repeated at different times/dates.
I tried all the optimizations suggested by the vodafone article 'Wie optimiere ich die WLAN-Leistung?' and following the manufacturer manual with no success. The modem model is Hitron CVE-30360 which has no 5GHz and according to manufacturer it can get up to 300 Mbit/s in WLAN.
I have this modem since 2015 and it cannot cope with my high speed Internet.
I kindly request the replacement of the modem which suits my new Internet plan and can get the expected speeds.
Thank you
5 Antworten 5
Tina
Hello Walrus,
welcome to our community. Nice to see you.
If you agree, you will get a new ( up-to-date ) cable router. The exchange is free of charge. Send me the following informations in a private message:
full name
date of birth
address
customer number
Write a short reply here afterwards.
Best regards
Tina
Walrus
Done!
thank you for your quick answer.
Best
Tina
Hallo Walrus,
where should the package be sent?
The return address for your old modem will be sent to you with the confirmation.
Best regards
Tina
Walrus
Hi Tina,
I sent you the address by private message.
Thank you
Hello Walrus,
You'll get a new cable router in the next few days. As soon as it is there, send the old cable routerback. You will find the address in the confirmation.
Best regards
Tina
