No data connection with DSL
Annu
Hello, I have a Vodafone connection and use this for my home office as well. This is not working from today evening. It shows signal connection with strength 'excellent' , but no data connection.
I have a toddler and sometimes work from home using this connection. Could you please check and rectify the problem?
Jens-K
Hi Annu,
what kind of conection do you use? DSL or cable?
Which modem do you use and did you check all cables and sockets? Also it can help to restart the modem.
Here you can check if there is a known issue with your connection: https://www.vodafone.de/hilfe/alles-zum-netz.html
Regards,
Jens
