Change Router and also check my plan
ssahoo
Digitalisierer
Digitalisierer
Hello Team,
I have two different requests for my connection
1. I would like to have an Dual band router, and would like to replace my current one with a dual band
2. When i took my plan, i wanted gigacombi.  Can anyone confirm if i am having gigacombi plan ?
Regards,
Subrat
Jens-K
Hi ssahoo,
which modem are you using right now?
If you are using the EasyBox 804 for free rent you can upgrade after 3 months. If you are using a FritzBox for rent you can change to another model after 24 months.
On your invoice you can see if the GigaKombi is active.
Did you check it already?
Regards,
Jens
Hello Jens,
I am currently using Fritzbox 7430, but i would like to have a dual band router.
Is there is a possibility that if i change my plan to 100 mbps, then can i get the dual band router ?
Also how to do i get my invoice from mein vodafone ? Could you please guide me the steps ?
Regards,
Subrat
Jens-K
Hi ssahoo,
in order to add your DSL contract to MeinVodafone log in to your account, click on "Vertrag hinzufügen" and type in the Online-Registrierungs-Code.
You find the code in our e-mail.
Changing from one FritzBox to another (for example FritzBox 7530 to 7590 or 7430 to 7590) is possible at the earliest after 24 months.
Regards,
Jens
