a sepcific Hostpot connection keeps breaking
maxgrillo
The connection to the WLAN Name: Vodafone Hotspot, Hotspot ID: HH-9-5802552 keeps breaking after few minutes that the connection is established. When the connection is available, signal is strong and speed is around 6/7 Mbps.
I tried other hotspot, this is the only Hotspot where this is happening and unfortunately it is the one I have close to home where I can connect.
Can you verify please or let me know if you need further details.
Thank you
Max
Hello maxgrillo,
as the Hotspot is provided by another customer we cannot give you information about this access. Please use a different Hotspot in your ambit.
Kind regards,
