Kantstrasse 125, Berlin hotspot not transmitting
sotirone
Hello,
The Kantstrasse 125 hotspot in Berlin has stopped working since Sunday. I can no longer see the wireless network.
I was using it for my work as it was the only one I could receive signal from. There is no longer a signal.
Please fix.
5 Antworten 5
ERFD
Hello sotirone,
can you tell us the ID of the spot? Sometimes the spot are provided by customer modems and they can simply turn off the spot.
Best regards Fred
The hotspot ID: SH-3-491
pRo-Marco
Hi sotirone,
I restartet the spot. Please try, if it works now.
Kind regards
It works now, thank you!
Hello sotirone,
thank you for feedback, I will close your thread now. You will get a PM with a survey in a few minutes, it would be great if you take part :).
Kind regards,
