Internet frequently down
lucoceano
My internet connection is frequently down, when running the diagnosis in the EasyBox 805, this is the message I get:
The following issues or information are present:
Error Codes
100304,200102
Very annoying behaviour, happens sometimes twice per day.
Andre
Hey lucoceano,
frequent disconnects are most likely a result of a defective landline , or router.
You can try to reset the easybox 805 to factorydefaults & reconfigure it with the modeminstallationcode.
If this is not working, my colleagues from the technical department need to have a closer look.
Since this community is mainly focused on customers helping other customers, i can't open a ticket for you.
In this case please call the customer support under 0800 172 1212,  so that they can check your landline.
Cheers,
Andre
