Problem bei der Installation
Nechi
Forum-Checker
Forum-Checker
Hello
I have a 4K Giga TV box.
I noticed a problem when I put the TV in the living room ... I don't have an antenna jack. I tried connecting the Giga TV box to my computer display using an HDMI Displayport cable, but it doesn't work.
Using long cables is not an option.
Do you have a possible solution for this?
many thanks
Moni_GK
Hello Nechi,
The GigaTV box needs a connection to an antenna socket.
Do you have none at all or do you just not have the socket at the right place?
Greetings Moni
