EasyBox 805 - Incapability to providing access with third party VPNs
Alexandros97
Youngster
Youngster
Hello, I am trying to connect through my company's vpn but this does not work. I tried on my phone data with hotspot and the vpn works correctly, so it seems to be a problem with your box and not the vpn config. Any idea what the problem might be?
natas666
not the router is the problem in this case - but the "iP-address-solution"
your router uses ds lite, I think.
so this means "iPv6" - accessing iPv4 addresses is onlly possible by something called "ds lite tunnel"
it transfers your iPv6 to iPv4 addresses
and exactly this is not good für most vpns
metal never dies
