Mail kommt nicht an
jhaeusle
Ich bekomme seit Tagen eine Antwort das meine Mail nicht angekommen ist. Kann den Fehlertext unten aber nicht interpretieren.
Was läuft hier falsch?
Es grüßt euch Jörg
This is the mail system at host mta-5-out.mta.xion.oxcs.net.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
<***@bigfoot.com>: host litemail18.bigfoot.net[38.102.228.18] said:
451 litemail19.bigfoot.net Connection timeout [192.168.13.52] (in reply to
MAIL FROM command)
Return-Path: <***@vodafone.de>
Received: from imap-backend-2.dovecot.xion.oxcs.net (imap-backend-2.dovecot.xion.oxcs.net [10.10.4.2])
by mta-5-out.mta.xion.oxcs.net (Postfix) with ESMTP id 1BE6680110A
for <***@bigfoot.com>; Sun, 24 Jun 2018 22:01:04 +0000 (UTC)
X-Sieve: Pigeonhole Sieve 0.4.devel (404c208)
X-Sieve-Redirected-From: 3@3648397
Delivered-To: 3@3648397
Received: from imap-director-4.novalocal ([10.10.2.6])
by imap-backend-2.dovecot.xion.oxcs.net with LMTP id GCAhOJ8UMFtRBwAAEQhufA
for <3@3648397>; Sun, 24 Jun 2018 22:01:03 +0000
Received: from vsmx002l.vodafonemail.xion.oxcs.net ([10.10.2.6])
by imap-director-4.novalocal with LMTP id mFbPN58UMFshDAAAIFweDA
Received: from vsmx002.vodafonemail.xion.oxcs.net (unknown [192.168.75.192])
(using TLSv1.2 with cipher AECDH-AES256-SHA (256/256 bits))
(No client certificate requested)
by vsmx002l.vodafonemail.xion.oxcs.net (Postfix) with ESMTPS id 41DR8H6JtMzHp2Q
for <***@vodafone.de>; Sun, 24 Jun 2018 22:01:03 +0000 (UTC)
Received: from mta-p1.oxcloud-vadesecure.net (mta-p1.oxcloud-vadesecure.net [157.97.76.183])
by vsmx002.vodafonemail.xion.oxcs.net (Postfix) with ESMTPS id 41DR8H65QWzHp2B
Received: from vsmx009.vodafonemail.xion.oxcs.net (vsmx009.vodafonemail.xion.oxcs.net [153.92.174.87])
(using TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384 (256/256 bits))
by mta-p1.oxcloud-vadesecure.net (ox1mtai56p) with ESMTPS id A538B2345BE
Received: from vsmx001.vodafonemail.xion.oxcs.net (unknown [192.168.75.191])
by mta-5-out.mta.xion.oxcs.net (Postfix) with ESMTP id 988BBC03EC
Received: from fritzbox (unknown [90.186.197.127])
by mta-5-out.mta.xion.oxcs.net (Postfix) with ESMTPA id 618D230005D
for <***@vodafone.de>; Sun, 24 Jun 2018 22:01:01 +0000 (UTC)
Message-Id: <[email protected]>
From: "=?UTF-8?B?RlJJVFohQm94IDc1OTAgamhhZXU=?=" <***@vodafone.de>
To: <***@vodafone.de>,
Date: Mon, 25 Jun 2018 00:01:02 +0200
Subject: =?UTF-8?B?RlJJVFohQm94LUluZm86IE51dHp1bmdzLSB1bmQgVmVyYmluZHVuZ3NkYXRlbiB2b20gMjQuMDYuMjAxOA==?=
Mime-Version: 1.0
Content-Type: multipart/mixed;
boundary="==AVM_Fritz_Box==multipart/mixed==0=="
X-VADE-STATUS: LEGIT
X-VRC-SPAM-STATUS: 0,0,gggruggvucftvghtrhhoucdtuddrgedtiedruddugddujedtucetufdoteggodetrfdotffvucfrrhhofhhilhgvmecuqfgigfgfnecuuegrihhlohhuthemuceftddunecunecujfgurhepkffhvfffufggtgesmhdtreertddtjeenucfhrhhomhepfdfhtffkvfgkvceuohigucejheeltdcujhhhrggvuhdfuceojhhovghrghdrhhgrvghushhlvghrsehvohgurghfohhnvgdruggvqeenucffohhmrghinheprghvmhdruggvpdhmhihfrhhithiirdhnvghtpdeltddrudekiedrudeljedruddvjedpsghighhfohhothdrtghomhenucfkphepudehfedrledvrddujeegrdekjedpledtrddukeeirdduleejrdduvdejnecurfgrrhgrmhepmhgrgihmshhgshhiiigvpedutdegkeehjeeipdhhvghlohepvhhsmhigtddtledrvhhouggrfhhonhgvmhgrihhlrdigihhonhdrohigtghsrdhnvghtpdhinhgvthepudehfedrledvrddujeegrdekjedpmhgrihhlfhhrohhmpehjohgvrhhgrdhhrggvuhhslhgvrhesvhhouggrfhhonhgvrdguvgdprhgtphhtthhopehjohgvrhhgrdhhrggvuhhslhgvrhesvhhouggrfhhonhgvrdguvgenucevlhhushhtvghrufhiiigvpedt
X-VRSPAM-STATE: legit
X-Spam-Flag: NO
X-VR-SPAM-STATE: 0
X-VR-SPAM-SCORE: 0
X-VR-SPF-RESULT: nil
X-Virus-Status-VR: clean
X-Virus-Status-CA: clean
X-Spam-Flag: NO
X-VRC-POLICY-STATUS: t=1,a=1,l=0
Edit @jhaeusle: Name entfernt und durch *** ersetzt.
Das musst Du vermutlich bei Bigfoot nachfragen, die Fehlermeldung ist nur die folgende:
das ist ein interner Fehler bei Bigfoot und könnte ein temporärer Fehler sein, d.h. der Server von Vodafone probiert es mehrmals aber die Mail kommt zurück wenn es gar nicht klappt.
arcor.de Freemailer
7 Antworten 7
alex_l
Full Metal User
Full Metal User
Ich würde das so lesen dass Deine Mails an [email protected] an [email protected] weitergeleitet werden und dieser Mailserver vom Mailserver von Vodafone aus keine Mails annimmt.
Falls Du das nicht selbst eingerichtet hast, könnte es sein dass Dein Account gehackt wurde und die Weiterleitung vom Hacker angelegt wurde.
arcor.de Freemailer
jhaeusle
Schade, ich dachte da steht mehr drin. Das die VF-Mails von bigfoot nicht an die endgültige Adresse geliefert werden habe ich ja schon bemerkt.
Bigfoot ist ein forwarding Service bei dem die endgültige Lieferadresse z.B. [email protected] hinterlegt ist.
Nur warum nimmt bigfoot keine VF-Mails an?
Gruß Jörg
arcor.de Freemailer
jhaeusle
Ok und danke. Das versuche ich dann mal.
pRo-Marco
Hallo jhaeusle,
melde Dich bitte noch einmal, wenn Du eine Info bekommen hast.
Leider keine vernünftige Antwort bekommen. Werde diesen Dienst kündigen müssen wenn sie hier keinen kontinuierlichen Sercie zur Verfügung stellen können. 😞
Bis denn dann
Grüße aus Berlin
Jörg
pRo-Marco
Hallo Jörg,
tut mir leid, dass der Dienst solche Probleme macht Smiley (traurig)
Kann ich den Thread damit schließen?
