[English] Vodafone Red Internet 1000 Cable maximum 75Mbit/s.
marcelcastilho
Hello,
I have a Vodafone Red Internet 1000 Cable plane but my download speed barely reachs 75Mbit / s.
I'm connected directly to the Vodafone modem using a LAN cable (CAT6), therefore the problem is not my WLAN.
I've tested several times a day using the Vodafone Speed ​​test. Using fast I get even less.
What should I do? Can you test on your side if you can deliver the contracted speed?
Thanks in advance, Marcel
5 Antworten 5
Wallace
Hi Marcel,
I cannot detect any bandwidth degradation. Is the bandwidth permanently so low or only after a certain time?
Regards
Wallace
Hi @Wallace .
Only certain times.
I also figured that my network was not configured for Gigabit Internet. It's faster now.
Thank you,
Marcel
Martin59
Hi marcelcastilho
does this mean that your connection is now working properly, or are there still impairments?
Best regards, Martin
Hi @Martin59 .
It's working properly. Thank you.
Best,
Marcel
Hello marcelcastilho,
thank you for your feedback. As the speed is fine now, I will close your thread.
Kind regards,
