Port forwarding cannot be set
Ivan_Atanasov
I would like to set up port forwarding to my local server, but there is no menu in the router where I can do that. Is it even possible with Vodafone's routers? Is there any way to do port forwarding?
reneromann
Port Forwarding using IPv4 is NOT possible if your device connects to the Internet using a DS-Lite tunnel (which is normal for cable contracts). The only option would be to open the firewall for IPv6 connections so that you may connect to your network using IPv6.
