WiFi Router blinking in red
Takehito
Hello please excuse me that i cannot write in Germain. My germain is not very good.
I am using the WiFi router certified 6.
There seems to be  problem with the internet connection. The WiFi is able to be connected with phones and laptops but there is no internet connection. I have tried the reset button and everything but does not work. I was able to use it in the morning but suddenly stoped.
I will appreciate if you can give me advice or instruction on how to fix this problem.
Thank you
MariaK
Hello @Takehito,
we are happy to help you! Our customer support is at your disposal and will be happy to answer your questions.
You can reach us via our WhatsApp chat on 0172 1217212 and we look forward to hearing from you!
Best regards
Maria
