am 17.01.2022 14:59
21.01.2022 19:59 - bearbeitet 21.01.2022 20:07
Der QFDMA Channel fällt übrigens auch ab. Sieht man in der GUI leider nicht.
Single-Carrier Channels: 8 (4 currently active) ID | Active | Frequency | SymRate | ChWidth | Attenuation | Power | Power16 | P-High | P-Low | P-DRW-High | P-DRW-Low | DeltaPF | Mod | Mux | | [MHz] | [MHz] | [kHz] | [dB] | [dBmV] | [dBmV] | [dBmV] | [dBmV] | [dBmV] | [dBmV] | [dB] | | ----+--------+-----------+---------+---------+-------------+--------+---------+----------+----------+------------+-----------+---------+---------+------ 5 | YES | 51.000 | 5.120 | 6400 | 15.956 | 48.021 | 42.000 | 49.500 | 17.000 | 46.000 | 34.000 | 0.000 | 64QAM | ATDMA 8 | YES | 30.800 | 5.120 | 6400 | 16.668 | 48.021 | 42.000 | 49.500 | 17.000 | 46.000 | 34.000 | 0.000 | 64QAM | ATDMA 7 | YES | 37.200 | 5.120 | 6400 | 16.459 | 48.021 | 42.000 | 49.500 | 17.000 | 46.000 | 34.000 | 0.000 | 16QAM | ATDMA 6 | YES | 44.600 | 5.120 | 6400 | 14.146 | 50.021 | 44.000 | 49.500 | 17.000 | 46.000 | 34.000 | 0.000 | 32QAM | ATDMA 0 | NO | 9.961 | 0.000 | 0 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | er | ATDMA 0 | NO | 9.961 | 0.000 | 0 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | er | ATDMA 0 | NO | 9.961 | 0.000 | 0 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | er | ATDMA 0 | NO | 9.961 | 0.000 | 0 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | er | ATDMA Multi-Carrier (OFDMA) Channels: 2 (1 currently active) ID | Active | First Subcarrier | Last Subcarrier | Active Subcarriers | Max Mod | Gain | Power | FFT Size | | [MHz] | [MHz] | | | [dB] | [dBmV] | ----+--------+------------------+-----------------+--------------------+---------+--------+--------+----------- 0 | YES | 29.800 | 64.750 | 640 | 128QAM | 0.171 | 44.000 | 4K 1 | NO | 0.000 | 0.000 | 0 | 0 | 0.000 | 0.000 | None
am 21.01.2022 21:12
am 23.01.2022 17:48
Sonntag 23.01.2022 17:45
Unverändert Probleme
Single-Carrier Channels: 8 (4 currently active) ID | Active | Frequency | SymRate | ChWidth | Attenuation | Power | Power16 | P-High | P-Low | P-DRW-High | P-DRW-Low | DeltaPF | Mod | Mux | | [MHz] | [MHz] | [kHz] | [dB] | [dBmV] | [dBmV] | [dBmV] | [dBmV] | [dBmV] | [dBmV] | [dB] | | ----+--------+-----------+---------+---------+-------------+--------+---------+----------+----------+------------+-----------+---------+---------+------ 7 | YES | 37.200 | 5.120 | 6400 | 16.459 | 48.021 | 42.000 | 49.500 | 17.000 | 46.250 | 34.250 | 0.000 | 32QAM | ATDMA 8 | YES | 30.800 | 5.120 | 6400 | 16.668 | 48.021 | 42.000 | 49.500 | 17.000 | 46.250 | 34.250 | 0.000 | 32QAM | ATDMA 5 | YES | 51.000 | 5.120 | 6400 | 15.956 | 48.021 | 42.000 | 49.500 | 17.000 | 46.250 | 34.250 | 0.000 | 32QAM | ATDMA 6 | YES | 44.600 | 5.120 | 6400 | 16.147 | 48.021 | 42.000 | 49.500 | 17.000 | 46.250 | 34.250 | 0.000 | 16QAM | ATDMA 0 | NO | 9.961 | 0.000 | 0 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | er | ATDMA 0 | NO | 9.961 | 0.000 | 0 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | er | ATDMA 0 | NO | 9.961 | 0.000 | 0 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | er | ATDMA 0 | NO | 9.961 | 0.000 | 0 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 | er | ATDMA Multi-Carrier (OFDMA) Channels: 2 (1 currently active) ID | Active | First Subcarrier | Last Subcarrier | Active Subcarriers | Max Mod | Gain | Power | FFT Size | | [MHz] | [MHz] | | | [dB] | [dBmV] | ----+--------+------------------+-----------------+--------------------+---------+--------+--------+----------- 0 | YES | 29.800 | 64.750 | 640 | 256QAM | 0.152 | 43.000 | 4K 1 | NO | 0.000 | 0.000 | 0 | 0 | 0.000 | 0.000 | None
23.01.2022 18:11 - bearbeitet 23.01.2022 18:14
am 23.01.2022 20:53
Für den Fall dass es wieder heißt ab Tag XYZ haben wir keine Störung mehr gesehen.
am 24.01.2022 14:24
Montag 24.01.2022
05:31:22.638: ==== Streaming Start ===============================================
05:31:24.058: [rtmp stream: 'adv_stream'] bitrate decreased to: 3000
05:31:25.114: [rtmp stream: 'adv_stream'] bitrate decreased to: 300
05:31:28.942: [rtmp stream: 'adv_stream'] bitrate decreased to: 200
05:31:58.946: [rtmp stream: 'adv_stream'] bitrate increased to: 800, waiting
05:32:28.948: [rtmp stream: 'adv_stream'] bitrate increased to: 1400, waiting
05:32:58.948: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
05:33:28.964: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
05:33:49.431: [rtmp stream: 'adv_stream'] going back to prev bitrate
05:33:49.431: [rtmp stream: 'adv_stream'] bitrate decreased to: 2000
05:34:19.447: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
05:34:49.447: [rtmp stream: 'adv_stream'] bitrate increased to: 3200, waiting
05:35:17.869: [rtmp stream: 'adv_stream'] bitrate decreased to: 3100
05:35:18.663: [rtmp stream: 'adv_stream'] bitrate decreased to: 2800
05:35:25.593: [rtmp stream: 'adv_stream'] bitrate decreased to: 2600
05:35:45.796: [rtmp stream: 'adv_stream'] bitrate decreased to: 2000
05:36:15.796: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
05:36:32.229: [rtmp stream: 'adv_stream'] going back to prev bitrate
05:36:32.229: [rtmp stream: 'adv_stream'] bitrate decreased to: 2000
05:36:51.029: [rtmp stream: 'adv_stream'] bitrate decreased to: 1800
05:36:52.193: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
05:37:22.195: [rtmp stream: 'adv_stream'] bitrate increased to: 1300, waiting
05:37:52.212: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
05:38:22.228: [rtmp stream: 'adv_stream'] bitrate increased to: 2500, waiting
05:38:52.244: [rtmp stream: 'adv_stream'] bitrate increased to: 3100, waiting
05:39:07.927: [rtmp stream: 'adv_stream'] bitrate decreased to: 3000
05:39:18.974: [rtmp stream: 'adv_stream'] bitrate decreased to: 2900
05:39:19.894: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
05:39:37.277: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
05:39:38.510: [rtmp stream: 'adv_stream'] bitrate decreased to: 300
05:40:08.510: [rtmp stream: 'adv_stream'] bitrate increased to: 900, waiting
05:40:38.526: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
05:40:57.821: adding 64 milliseconds of audio buffering, total audio buffering is now 85 milliseconds (source: Medienquelle)
05:40:57.821:
05:41:08.531: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
05:41:38.543: [rtmp stream: 'adv_stream'] bitrate increased to: 2700, waiting
05:42:08.551: [rtmp stream: 'adv_stream'] bitrate increased to: 3300, waiting
05:42:15.009: [rtmp stream: 'adv_stream'] bitrate decreased to: 3100
05:42:19.472: [rtmp stream: 'adv_stream'] bitrate decreased to: 2900
05:42:20.800: [rtmp stream: 'adv_stream'] bitrate decreased to: 800
05:42:23.392: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
05:42:24.402: [rtmp stream: 'adv_stream'] bitrate decreased to: 400
05:42:54.405: [rtmp stream: 'adv_stream'] bitrate increased to: 1000, waiting
05:43:24.425: [rtmp stream: 'adv_stream'] bitrate increased to: 1600, waiting
05:43:42.874: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
05:44:09.774: [rtmp stream: 'adv_stream'] bitrate decreased to: 1100
05:44:11.508: [rtmp stream: 'adv_stream'] bitrate decreased to: 100
05:44:41.515: [rtmp stream: 'adv_stream'] bitrate increased to: 700, waiting
05:45:11.517: [rtmp stream: 'adv_stream'] bitrate increased to: 1300, waiting
05:45:13.175: [rtmp stream: 'adv_stream'] bitrate decreased to: 800
05:45:43.181: [rtmp stream: 'adv_stream'] bitrate increased to: 1400, waiting
05:46:13.184: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
05:46:21.040: [rtmp stream: 'adv_stream'] bitrate decreased to: 1900
05:46:25.494: [rtmp stream: 'adv_stream'] bitrate decreased to: 1700
05:46:26.837: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
05:46:56.856: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
05:47:26.872: [rtmp stream: 'adv_stream'] bitrate increased to: 2500, waiting
05:47:56.878: [rtmp stream: 'adv_stream'] bitrate increased to: 3100, waiting
05:48:26.885: [rtmp stream: 'adv_stream'] bitrate increased to: 3700, waiting
05:48:40.855: [rtmp stream: 'adv_stream'] bitrate decreased to: 3400
05:48:42.562: [rtmp stream: 'adv_stream'] bitrate decreased to: 300
05:49:12.578: [rtmp stream: 'adv_stream'] bitrate increased to: 900, waiting
05:49:42.598: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
05:50:12.612: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
05:50:13.054: [rtmp stream: 'adv_stream'] bitrate decreased to: 1600
05:50:43.070: [rtmp stream: 'adv_stream'] bitrate increased to: 2200, waiting
05:51:13.079: [rtmp stream: 'adv_stream'] bitrate increased to: 2800, waiting
05:51:43.082: [rtmp stream: 'adv_stream'] bitrate increased to: 3400, waiting
05:52:13.092: [rtmp stream: 'adv_stream'] bitrate increased to: 4000, waiting
05:52:43.108: [rtmp stream: 'adv_stream'] bitrate increased to: 4600, waiting
05:53:13.120: [rtmp stream: 'adv_stream'] bitrate increased to: 5200, waiting
05:53:27.339: [rtmp stream: 'adv_stream'] going back to prev bitrate
05:53:27.339: [rtmp stream: 'adv_stream'] bitrate decreased to: 4600
05:53:37.964: [rtmp stream: 'adv_stream'] bitrate decreased to: 4400
05:53:38.968: [rtmp stream: 'adv_stream'] bitrate decreased to: 1100
05:54:08.970: [rtmp stream: 'adv_stream'] bitrate increased to: 1700, waiting
05:54:19.435: [rtmp stream: 'adv_stream'] bitrate decreased to: 1600
05:54:36.074: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
05:54:38.534: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
05:54:39.460: [rtmp stream: 'adv_stream'] bitrate decreased to: 200
05:55:09.476: [rtmp stream: 'adv_stream'] bitrate increased to: 800, waiting
05:55:39.490: [rtmp stream: 'adv_stream'] bitrate increased to: 1400, waiting
05:56:09.510: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
05:56:39.530: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
05:57:09.549: [rtmp stream: 'adv_stream'] bitrate increased to: 3200, waiting
05:57:12.066: [rtmp stream: 'adv_stream'] bitrate decreased to: 3100
05:57:12.999: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
05:57:15.566: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
05:57:45.579: [rtmp stream: 'adv_stream'] bitrate increased to: 1800, waiting
05:58:15.592: [rtmp stream: 'adv_stream'] bitrate increased to: 2400, waiting
05:58:28.049: [rtmp stream: 'adv_stream'] going back to prev bitrate
05:58:28.049: [rtmp stream: 'adv_stream'] bitrate decreased to: 1800
05:58:36.501: [rtmp stream: 'adv_stream'] bitrate decreased to: 1700
05:59:06.505: [rtmp stream: 'adv_stream'] bitrate increased to: 2300, waiting
05:59:36.507: [rtmp stream: 'adv_stream'] bitrate increased to: 2900, waiting
06:00:06.522: [rtmp stream: 'adv_stream'] bitrate increased to: 3500, waiting
06:00:36.535: [rtmp stream: 'adv_stream'] bitrate increased to: 4100, waiting
06:00:48.830: [rtmp stream: 'adv_stream'] bitrate decreased to: 4000
06:00:51.081: [rtmp stream: 'adv_stream'] bitrate decreased to: 3800
06:00:52.447: [rtmp stream: 'adv_stream'] bitrate decreased to: 3200
06:00:53.457: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
06:01:23.476: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
06:01:53.481: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
06:02:22.096: [rtmp stream: 'adv_stream'] going back to prev bitrate
06:02:22.096: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
06:02:52.101: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
06:03:22.118: [rtmp stream: 'adv_stream'] bitrate increased to: 2700, waiting
06:03:52.121: [rtmp stream: 'adv_stream'] bitrate increased to: 3300, waiting
06:04:22.134: [rtmp stream: 'adv_stream'] bitrate increased to: 3900, waiting
06:04:43.628: [rtmp stream: 'adv_stream'] bitrate decreased to: 3600
06:04:44.764: [rtmp stream: 'adv_stream'] bitrate decreased to: 1600
06:04:45.983: [rtmp stream: 'adv_stream'] bitrate decreased to: 1100
06:05:15.996: [rtmp stream: 'adv_stream'] bitrate increased to: 1700, waiting
06:05:46.005: [rtmp stream: 'adv_stream'] bitrate increased to: 2300, waiting
06:06:16.010: [rtmp stream: 'adv_stream'] bitrate increased to: 2900, waiting
06:06:46.020: [rtmp stream: 'adv_stream'] bitrate increased to: 3500, waiting
06:07:16.027: [rtmp stream: 'adv_stream'] bitrate increased to: 4100, waiting
06:07:45.653: [rtmp stream: 'adv_stream'] bitrate decreased to: 4000
06:07:46.443: [rtmp stream: 'adv_stream'] bitrate decreased to: 100
06:08:16.443: [rtmp stream: 'adv_stream'] bitrate increased to: 700, waiting
06:08:46.454: [rtmp stream: 'adv_stream'] bitrate increased to: 1300, waiting
06:09:16.472: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
06:09:46.478: [rtmp stream: 'adv_stream'] bitrate increased to: 2500, waiting
06:10:16.492: [rtmp stream: 'adv_stream'] bitrate increased to: 3100, waiting
06:10:24.954: [rtmp stream: 'adv_stream'] bitrate decreased to: 2900
06:10:25.917: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
06:10:49.186: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
06:10:50.714: [rtmp stream: 'adv_stream'] bitrate decreased to: 600
06:10:52.163: [rtmp stream: 'adv_stream'] bitrate decreased to: 200
06:11:22.167: [rtmp stream: 'adv_stream'] bitrate increased to: 800, waiting
06:11:52.178: [rtmp stream: 'adv_stream'] bitrate increased to: 1400, waiting
06:11:56.814: [rtmp stream: 'adv_stream'] going back to prev bitrate
06:11:56.814: [rtmp stream: 'adv_stream'] bitrate decreased to: 800
06:12:02.057: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
06:12:32.062: [rtmp stream: 'adv_stream'] bitrate increased to: 1300, waiting
06:13:02.073: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
06:13:09.402: [rtmp stream: 'adv_stream'] bitrate decreased to: 1800
06:13:10.368: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
06:13:12.681: [rtmp stream: 'adv_stream'] bitrate decreased to: 1100
06:13:42.687: [rtmp stream: 'adv_stream'] bitrate increased to: 1700, waiting
06:14:12.705: [rtmp stream: 'adv_stream'] bitrate increased to: 2300, waiting
06:14:42.712: [rtmp stream: 'adv_stream'] bitrate increased to: 2900, waiting
06:15:12.717: [rtmp stream: 'adv_stream'] bitrate increased to: 3500, waiting
06:15:30.722: [rtmp stream: 'adv_stream'] bitrate decreased to: 3200
06:15:31.739: [rtmp stream: 'adv_stream'] bitrate decreased to: 1800
06:15:36.630: [rtmp stream: 'adv_stream'] bitrate decreased to: 1700
06:16:06.638: [rtmp stream: 'adv_stream'] bitrate increased to: 2300, waiting
06:16:36.637: [rtmp stream: 'adv_stream'] bitrate increased to: 2900, waiting
06:17:06.654: [rtmp stream: 'adv_stream'] bitrate increased to: 3500, waiting
06:17:36.654: [rtmp stream: 'adv_stream'] bitrate increased to: 4100, waiting
06:17:53.106: [rtmp stream: 'adv_stream'] bitrate decreased to: 3900
06:17:54.092: [rtmp stream: 'adv_stream'] bitrate decreased to: 1700
06:18:24.100: [rtmp stream: 'adv_stream'] bitrate increased to: 2300, waiting
06:18:54.112: [rtmp stream: 'adv_stream'] bitrate increased to: 2900, waiting
06:19:24.120: [rtmp stream: 'adv_stream'] bitrate increased to: 3500, waiting
06:19:54.136: [rtmp stream: 'adv_stream'] bitrate increased to: 4100, waiting
06:20:14.596: [rtmp stream: 'adv_stream'] bitrate decreased to: 3500
06:20:15.416: [rtmp stream: 'adv_stream'] bitrate decreased to: 3200
06:20:20.534: [rtmp stream: 'adv_stream'] bitrate decreased to: 2500
06:20:25.135: [rtmp stream: 'adv_stream'] bitrate decreased to: 2300
06:20:28.528: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
06:20:38.703: [rtmp stream: 'adv_stream'] bitrate decreased to: 2100
06:20:40.343: [rtmp stream: 'adv_stream'] bitrate decreased to: 500
06:20:43.913: [rtmp stream: 'adv_stream'] bitrate decreased to: 400
06:20:44.951: [rtmp stream: 'adv_stream'] bitrate decreased to: 300
06:20:50.761: [rtmp stream: 'adv_stream'] bitrate decreased to: 200
06:21:20.770: [rtmp stream: 'adv_stream'] bitrate increased to: 800, waiting
06:21:50.780: [rtmp stream: 'adv_stream'] bitrate increased to: 1400, waiting
06:22:20.797: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
06:22:29.401: [rtmp stream: 'adv_stream'] going back to prev bitrate
06:22:29.401: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
06:22:32.367: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
06:22:33.398: [rtmp stream: 'adv_stream'] bitrate decreased to: 400
06:22:34.927: [rtmp stream: 'adv_stream'] bitrate decreased to: 200
06:23:04.939: [rtmp stream: 'adv_stream'] bitrate increased to: 800, waiting
06:23:34.956: [rtmp stream: 'adv_stream'] bitrate increased to: 1400, waiting
06:24:04.970: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
06:24:34.988: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
06:24:59.432: [rtmp stream: 'adv_stream'] bitrate decreased to: 2400
06:25:00.890: [rtmp stream: 'adv_stream'] bitrate decreased to: 600
06:25:30.900: [rtmp stream: 'adv_stream'] bitrate increased to: 1200, waiting
06:26:00.912: [rtmp stream: 'adv_stream'] bitrate increased to: 1800, waiting
06:26:30.928: [rtmp stream: 'adv_stream'] bitrate increased to: 2400, waiting
06:26:57.366: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
06:26:58.394: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
06:27:28.414: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
06:27:40.866: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
06:28:10.870: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
06:28:40.875: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
06:29:10.886: [rtmp stream: 'adv_stream'] bitrate increased to: 3200, waiting
06:29:40.901: [rtmp stream: 'adv_stream'] bitrate increased to: 3800, waiting
06:29:44.706: [rtmp stream: 'adv_stream'] bitrate decreased to: 3700
06:29:45.717: [rtmp stream: 'adv_stream'] bitrate decreased to: 100
06:30:15.723: [rtmp stream: 'adv_stream'] bitrate increased to: 700, waiting
06:30:45.729: [rtmp stream: 'adv_stream'] bitrate increased to: 1300, waiting
06:31:15.747: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
06:31:45.756: [rtmp stream: 'adv_stream'] bitrate increased to: 2500, waiting
06:32:04.208: [rtmp stream: 'adv_stream'] bitrate decreased to: 2300
06:32:05.388: [rtmp stream: 'adv_stream'] bitrate decreased to: 500
06:32:35.388: [rtmp stream: 'adv_stream'] bitrate increased to: 1100, waiting
06:32:58.007: [rtmp stream: 'adv_stream'] going back to prev bitrate
06:32:58.007: [rtmp stream: 'adv_stream'] bitrate decreased to: 500
06:33:28.011: [rtmp stream: 'adv_stream'] bitrate increased to: 1100, waiting
06:33:58.027: [rtmp stream: 'adv_stream'] bitrate increased to: 1700, waiting
06:34:05.198: [rtmp stream: 'adv_stream'] going back to prev bitrate
06:34:05.198: [rtmp stream: 'adv_stream'] bitrate decreased to: 1100
06:34:07.611: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
06:34:10.581: [rtmp stream: 'adv_stream'] bitrate decreased to: 800
06:34:13.310: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
06:34:43.316: [rtmp stream: 'adv_stream'] bitrate increased to: 1300, waiting
06:35:13.318: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
06:35:17.776: [rtmp stream: 'adv_stream'] bitrate decreased to: 1800
06:35:22.765: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
06:35:24.503: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
06:35:25.598: [rtmp stream: 'adv_stream'] bitrate decreased to: 300
06:35:55.606: [rtmp stream: 'adv_stream'] bitrate increased to: 900, waiting
06:36:25.620: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
06:36:36.075: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
06:36:36.829: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
06:36:37.965: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
06:36:39.394: [rtmp stream: 'adv_stream'] bitrate decreased to: 300
06:36:46.908: [rtmp stream: 'adv_stream'] bitrate decreased to: 200
06:37:16.925: [rtmp stream: 'adv_stream'] bitrate increased to: 800, waiting
06:37:46.939: [rtmp stream: 'adv_stream'] bitrate increased to: 1400, waiting
06:37:51.374: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
06:37:54.172: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
06:37:55.429: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
06:37:57.101: [rtmp stream: 'adv_stream'] bitrate decreased to: 300
06:38:27.104: [rtmp stream: 'adv_stream'] bitrate increased to: 900, waiting
06:38:57.124: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
06:39:27.140: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
06:39:42.699: [rtmp stream: 'adv_stream'] bitrate decreased to: 2000
06:39:43.574: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
06:39:44.582: [rtmp stream: 'adv_stream'] bitrate decreased to: 400
06:40:14.595: [rtmp stream: 'adv_stream'] bitrate increased to: 1000, waiting
06:40:44.596: [rtmp stream: 'adv_stream'] bitrate increased to: 1600, waiting
06:41:14.595: [rtmp stream: 'adv_stream'] bitrate increased to: 2200, waiting
06:41:44.612: [rtmp stream: 'adv_stream'] bitrate increased to: 2800, waiting
06:42:07.173: [rtmp stream: 'adv_stream'] going back to prev bitrate
06:42:07.173: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
06:42:12.131: [rtmp stream: 'adv_stream'] bitrate decreased to: 1900
06:42:42.140: [rtmp stream: 'adv_stream'] bitrate increased to: 2500, waiting
06:43:12.156: [rtmp stream: 'adv_stream'] bitrate increased to: 3100, waiting
06:43:42.171: [rtmp stream: 'adv_stream'] bitrate increased to: 3700, waiting
06:44:12.171: [rtmp stream: 'adv_stream'] bitrate increased to: 4300, waiting
06:44:40.626: [rtmp stream: 'adv_stream'] bitrate decreased to: 4100
06:45:04.389: [rtmp stream: 'adv_stream'] bitrate decreased to: 4000
06:45:05.213: [rtmp stream: 'adv_stream'] bitrate decreased to: 500
06:45:12.839: [rtmp stream: 'adv_stream'] bitrate decreased to: 400
06:45:42.839: [rtmp stream: 'adv_stream'] bitrate increased to: 1000, waiting
06:46:12.853: [rtmp stream: 'adv_stream'] bitrate increased to: 1600, waiting
06:46:42.854: [rtmp stream: 'adv_stream'] bitrate increased to: 2200, waiting
06:47:12.866: [rtmp stream: 'adv_stream'] bitrate increased to: 2800, waiting
06:47:30.531: [rtmp stream: 'adv_stream'] going back to prev bitrate
06:47:30.531: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
06:47:51.202: [rtmp stream: 'adv_stream'] bitrate decreased to: 2100
06:47:52.286: [rtmp stream: 'adv_stream'] bitrate decreased to: 200
06:48:22.295: [rtmp stream: 'adv_stream'] bitrate increased to: 800, waiting
06:48:52.311: [rtmp stream: 'adv_stream'] bitrate increased to: 1400, waiting
06:49:22.318: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
06:49:52.334: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
06:50:08.630: [rtmp stream: 'adv_stream'] bitrate decreased to: 2400
06:50:09.717: [rtmp stream: 'adv_stream'] bitrate decreased to: 1000
06:50:12.977: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
06:50:42.986: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
06:51:13.005: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
06:51:43.033: [rtmp stream: 'adv_stream'] bitrate increased to: 2700, waiting
06:51:45.608: [rtmp stream: 'adv_stream'] bitrate decreased to: 2600
06:51:46.566: [rtmp stream: 'adv_stream'] bitrate decreased to: 200
06:52:16.583: [rtmp stream: 'adv_stream'] bitrate increased to: 800, waiting
06:52:46.592: [rtmp stream: 'adv_stream'] bitrate increased to: 1400, waiting
06:53:16.592: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
06:53:33.382: [rtmp stream: 'adv_stream'] going back to prev bitrate
06:53:33.382: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
06:54:03.398: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
06:54:05.999: [rtmp stream: 'adv_stream'] going back to prev bitrate
06:54:05.999: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
06:54:35.999: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
06:55:06.015: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
06:55:32.847: [rtmp stream: 'adv_stream'] going back to prev bitrate
06:55:32.847: [rtmp stream: 'adv_stream'] bitrate decreased to: 2000
06:55:41.314: [rtmp stream: 'adv_stream'] bitrate decreased to: 1900
06:55:51.764: [rtmp stream: 'adv_stream'] bitrate decreased to: 1800
06:56:21.764: [rtmp stream: 'adv_stream'] bitrate increased to: 2400, waiting
06:56:34.220: [rtmp stream: 'adv_stream'] bitrate decreased to: 2300
06:56:38.680: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
06:56:41.138: [rtmp stream: 'adv_stream'] bitrate decreased to: 2100
06:56:44.137: [rtmp stream: 'adv_stream'] bitrate decreased to: 1900
06:56:45.190: [rtmp stream: 'adv_stream'] bitrate decreased to: 200
06:57:15.191: [rtmp stream: 'adv_stream'] bitrate increased to: 800, waiting
06:57:45.196: [rtmp stream: 'adv_stream'] bitrate increased to: 1400, waiting
06:58:15.212: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
06:58:45.226: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
06:59:05.667: [rtmp stream: 'adv_stream'] bitrate decreased to: 2500
06:59:35.679: [rtmp stream: 'adv_stream'] bitrate increased to: 3100, waiting
07:00:05.693: [rtmp stream: 'adv_stream'] bitrate increased to: 3700, waiting
07:00:35.695: [rtmp stream: 'adv_stream'] bitrate increased to: 4300, waiting
07:00:59.772: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:00:59.772: [rtmp stream: 'adv_stream'] bitrate decreased to: 3700
07:01:08.220: [rtmp stream: 'adv_stream'] bitrate decreased to: 3600
07:01:09.187: [rtmp stream: 'adv_stream'] bitrate decreased to: 3200
07:01:13.635: [rtmp stream: 'adv_stream'] bitrate decreased to: 3100
07:01:18.082: [rtmp stream: 'adv_stream'] bitrate decreased to: 3000
07:01:48.094: [rtmp stream: 'adv_stream'] bitrate increased to: 3600, waiting
07:02:18.104: [rtmp stream: 'adv_stream'] bitrate increased to: 4200, waiting
07:02:21.914: [rtmp stream: 'adv_stream'] bitrate decreased to: 4100
07:02:22.903: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
07:02:52.919: [rtmp stream: 'adv_stream'] bitrate increased to: 1300, waiting
07:03:22.926: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
07:03:52.931: [rtmp stream: 'adv_stream'] bitrate increased to: 2500, waiting
07:04:22.938: [rtmp stream: 'adv_stream'] bitrate increased to: 3100, waiting
07:04:43.642: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:04:43.642: [rtmp stream: 'adv_stream'] bitrate decreased to: 2500
07:04:46.619: [rtmp stream: 'adv_stream'] bitrate decreased to: 2300
07:04:47.642: [rtmp stream: 'adv_stream'] bitrate decreased to: 1000
07:05:17.658: [rtmp stream: 'adv_stream'] bitrate increased to: 1600, waiting
07:05:47.672: [rtmp stream: 'adv_stream'] bitrate increased to: 2200, waiting
07:06:02.175: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:06:02.175: [rtmp stream: 'adv_stream'] bitrate decreased to: 1600
07:06:05.367: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
07:06:35.384: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
07:07:05.399: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
07:07:35.416: [rtmp stream: 'adv_stream'] bitrate increased to: 3200, waiting
07:08:05.433: [rtmp stream: 'adv_stream'] bitrate increased to: 3800, waiting
07:08:09.600: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:08:09.600: [rtmp stream: 'adv_stream'] bitrate decreased to: 3200
07:08:10.557: [rtmp stream: 'adv_stream'] bitrate decreased to: 3000
07:08:14.157: [rtmp stream: 'adv_stream'] bitrate decreased to: 2800
07:08:22.607: [rtmp stream: 'adv_stream'] bitrate decreased to: 2700
07:08:52.623: [rtmp stream: 'adv_stream'] bitrate increased to: 3300, waiting
07:08:57.640: [rtmp stream: 'adv_stream'] bitrate decreased to: 3000
07:09:02.094: [rtmp stream: 'adv_stream'] bitrate decreased to: 2900
07:09:03.165: [rtmp stream: 'adv_stream'] bitrate decreased to: 2100
07:09:17.727: [rtmp stream: 'adv_stream'] bitrate decreased to: 2000
07:09:47.745: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
07:10:17.753: [rtmp stream: 'adv_stream'] bitrate increased to: 3200, waiting
07:10:30.202: [rtmp stream: 'adv_stream'] bitrate decreased to: 3100
07:10:33.388: [rtmp stream: 'adv_stream'] bitrate decreased to: 2300
07:10:34.547: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
07:10:40.400: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
07:11:10.401: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
07:11:40.409: [rtmp stream: 'adv_stream'] bitrate increased to: 2500, waiting
07:12:10.413: [rtmp stream: 'adv_stream'] bitrate increased to: 3100, waiting
07:12:40.415: [rtmp stream: 'adv_stream'] bitrate increased to: 3700, waiting
07:13:10.429: [rtmp stream: 'adv_stream'] bitrate increased to: 4300, waiting
07:13:40.445: [rtmp stream: 'adv_stream'] bitrate increased to: 4900, waiting
07:13:43.653: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:13:43.653: [rtmp stream: 'adv_stream'] bitrate decreased to: 4300
07:13:45.286: [rtmp stream: 'adv_stream'] bitrate decreased to: 3900
07:13:46.380: [rtmp stream: 'adv_stream'] bitrate decreased to: 2900
07:14:16.383: [rtmp stream: 'adv_stream'] bitrate increased to: 3500, waiting
07:14:46.399: [rtmp stream: 'adv_stream'] bitrate increased to: 4100, waiting
07:15:16.412: [rtmp stream: 'adv_stream'] bitrate increased to: 4700, waiting
07:15:46.419: [rtmp stream: 'adv_stream'] bitrate increased to: 5300, waiting
07:16:04.618: [rtmp stream: 'adv_stream'] bitrate decreased to: 5200
07:16:05.435: [rtmp stream: 'adv_stream'] bitrate decreased to: 3400
07:16:06.435: [rtmp stream: 'adv_stream'] bitrate decreased to: 2500
07:16:07.558: [rtmp stream: 'adv_stream'] bitrate decreased to: 2400
07:16:20.423: [rtmp stream: 'adv_stream'] bitrate decreased to: 2300
07:16:24.882: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
07:16:25.783: [rtmp stream: 'adv_stream'] bitrate decreased to: 600
07:16:55.791: [rtmp stream: 'adv_stream'] bitrate increased to: 1200, waiting
07:17:25.795: [rtmp stream: 'adv_stream'] bitrate increased to: 1800, waiting
07:17:42.235: [rtmp stream: 'adv_stream'] bitrate decreased to: 1700
07:18:12.250: [rtmp stream: 'adv_stream'] bitrate increased to: 2300, waiting
07:18:42.250: [rtmp stream: 'adv_stream'] bitrate increased to: 2900, waiting
07:19:12.264: [rtmp stream: 'adv_stream'] bitrate increased to: 3500, waiting
07:19:42.275: [rtmp stream: 'adv_stream'] bitrate increased to: 4100, waiting
07:19:57.489: [rtmp stream: 'adv_stream'] bitrate decreased to: 3700
07:19:58.392: [rtmp stream: 'adv_stream'] bitrate decreased to: 3100
07:19:59.437: [rtmp stream: 'adv_stream'] bitrate decreased to: 2500
07:20:05.894: [rtmp stream: 'adv_stream'] bitrate decreased to: 2400
07:20:11.664: [rtmp stream: 'adv_stream'] bitrate decreased to: 2300
07:20:30.116: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
07:20:35.121: [rtmp stream: 'adv_stream'] bitrate decreased to: 2000
07:20:39.583: [rtmp stream: 'adv_stream'] bitrate decreased to: 1900
07:20:40.716: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
07:20:41.712: [rtmp stream: 'adv_stream'] bitrate decreased to: 1000
07:20:42.755: [rtmp stream: 'adv_stream'] bitrate decreased to: 800
07:21:12.769: [rtmp stream: 'adv_stream'] bitrate increased to: 1400, waiting
07:21:42.775: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
07:22:12.783: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
07:22:42.791: [rtmp stream: 'adv_stream'] bitrate increased to: 3200, waiting
07:23:12.797: [rtmp stream: 'adv_stream'] bitrate increased to: 3800, waiting
07:23:35.253: [rtmp stream: 'adv_stream'] bitrate decreased to: 3600
07:23:36.066: [rtmp stream: 'adv_stream'] bitrate decreased to: 2700
07:23:37.370: [rtmp stream: 'adv_stream'] bitrate decreased to: 800
07:24:07.385: [rtmp stream: 'adv_stream'] bitrate increased to: 1400, waiting
07:24:07.843: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
07:24:08.807: [rtmp stream: 'adv_stream'] bitrate decreased to: 300
07:24:38.813: [rtmp stream: 'adv_stream'] bitrate increased to: 900, waiting
07:25:08.830: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
07:25:38.842: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
07:25:47.963: [rtmp stream: 'adv_stream'] bitrate decreased to: 2000
07:25:49.242: [rtmp stream: 'adv_stream'] bitrate decreased to: 400
07:26:19.255: [rtmp stream: 'adv_stream'] bitrate increased to: 1000, waiting
07:26:21.953: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
07:26:23.303: [rtmp stream: 'adv_stream'] bitrate decreased to: 400
07:26:53.305: [rtmp stream: 'adv_stream'] bitrate increased to: 1000, waiting
07:27:23.308: [rtmp stream: 'adv_stream'] bitrate increased to: 1600, waiting
07:27:53.311: [rtmp stream: 'adv_stream'] bitrate increased to: 2200, waiting
07:28:23.312: [rtmp stream: 'adv_stream'] bitrate increased to: 2800, waiting
07:28:53.318: [rtmp stream: 'adv_stream'] bitrate increased to: 3400, waiting
07:28:59.761: [rtmp stream: 'adv_stream'] bitrate decreased to: 3300
07:29:02.998: [rtmp stream: 'adv_stream'] bitrate decreased to: 2600
07:29:04.027: [rtmp stream: 'adv_stream'] bitrate decreased to: 300
07:29:34.035: [rtmp stream: 'adv_stream'] bitrate increased to: 900, waiting
07:30:04.035: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
07:30:34.046: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
07:30:44.497: [rtmp stream: 'adv_stream'] bitrate decreased to: 2000
07:31:01.426: [rtmp stream: 'adv_stream'] bitrate decreased to: 1800
07:31:23.893: [rtmp stream: 'adv_stream'] bitrate decreased to: 1700
07:31:24.673: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
07:31:54.690: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
07:32:24.692: [rtmp stream: 'adv_stream'] bitrate increased to: 2700, waiting
07:32:53.143: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:32:53.144: [rtmp stream: 'adv_stream'] bitrate decreased to: 2100
07:33:23.158: [rtmp stream: 'adv_stream'] bitrate increased to: 2700, waiting
07:33:41.614: [rtmp stream: 'adv_stream'] bitrate decreased to: 2600
07:34:11.634: [rtmp stream: 'adv_stream'] bitrate increased to: 3200, waiting
07:34:40.502: [rtmp stream: 'adv_stream'] bitrate decreased to: 2900
07:34:41.670: [rtmp stream: 'adv_stream'] bitrate decreased to: 400
07:35:11.688: [rtmp stream: 'adv_stream'] bitrate increased to: 1000, waiting
07:35:41.695: [rtmp stream: 'adv_stream'] bitrate increased to: 1600, waiting
07:36:11.697: [rtmp stream: 'adv_stream'] bitrate increased to: 2200, waiting
07:36:41.706: [rtmp stream: 'adv_stream'] bitrate increased to: 2800, waiting
07:37:06.232: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:37:06.232: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
07:37:23.206: [rtmp stream: 'adv_stream'] bitrate decreased to: 1700
07:37:24.411: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
07:37:25.927: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
07:37:55.944: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
07:38:25.950: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
07:38:55.955: [rtmp stream: 'adv_stream'] bitrate increased to: 2700, waiting
07:39:25.955: [rtmp stream: 'adv_stream'] bitrate increased to: 3300, waiting
07:39:32.288: [rtmp stream: 'adv_stream'] bitrate decreased to: 3000
07:39:33.488: [rtmp stream: 'adv_stream'] bitrate decreased to: 1800
07:39:34.788: [rtmp stream: 'adv_stream'] bitrate decreased to: 500
07:40:04.798: [rtmp stream: 'adv_stream'] bitrate increased to: 1100, waiting
07:40:34.818: [rtmp stream: 'adv_stream'] bitrate increased to: 1700, waiting
07:41:04.825: [rtmp stream: 'adv_stream'] bitrate increased to: 2300, waiting
07:41:15.287: [rtmp stream: 'adv_stream'] bitrate decreased to: 2100
07:41:45.303: [rtmp stream: 'adv_stream'] bitrate increased to: 2700, waiting
07:42:09.770: [rtmp stream: 'adv_stream'] bitrate decreased to: 2600
07:42:12.219: [rtmp stream: 'adv_stream'] bitrate decreased to: 2500
07:42:23.045: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
07:42:24.543: [rtmp stream: 'adv_stream'] bitrate decreased to: 1000
07:42:25.799: [rtmp stream: 'adv_stream'] bitrate decreased to: 500
07:42:55.803: [rtmp stream: 'adv_stream'] bitrate increased to: 1100, waiting
07:43:25.814: [rtmp stream: 'adv_stream'] bitrate increased to: 1700, waiting
07:43:55.832: [rtmp stream: 'adv_stream'] bitrate increased to: 2300, waiting
07:44:25.851: [rtmp stream: 'adv_stream'] bitrate increased to: 2900, waiting
07:44:44.968: [rtmp stream: 'adv_stream'] bitrate decreased to: 2800
07:44:45.868: [rtmp stream: 'adv_stream'] bitrate decreased to: 100
07:45:15.872: [rtmp stream: 'adv_stream'] bitrate increased to: 700, waiting
07:45:45.877: [rtmp stream: 'adv_stream'] bitrate increased to: 1300, waiting
07:46:15.877: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
07:46:28.350: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:46:28.350: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
07:46:31.873: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
07:47:01.883: [rtmp stream: 'adv_stream'] bitrate increased to: 1800, waiting
07:47:31.889: [rtmp stream: 'adv_stream'] bitrate increased to: 2400, waiting
07:47:36.066: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:47:36.066: [rtmp stream: 'adv_stream'] bitrate decreased to: 1800
07:47:44.992: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
07:48:14.992: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
07:48:19.449: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:48:19.449: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
07:48:40.271: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
07:49:10.275: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
07:49:28.715: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:49:28.715: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
07:49:58.725: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
07:50:28.731: [rtmp stream: 'adv_stream'] bitrate increased to: 2500, waiting
07:50:58.748: [rtmp stream: 'adv_stream'] bitrate increased to: 3100, waiting
07:51:28.764: [rtmp stream: 'adv_stream'] bitrate increased to: 3700, waiting
07:51:46.631: [rtmp stream: 'adv_stream'] bitrate decreased to: 3400
07:51:47.429: [rtmp stream: 'adv_stream'] bitrate decreased to: 400
07:52:17.447: [rtmp stream: 'adv_stream'] bitrate increased to: 1000, waiting
07:52:47.457: [rtmp stream: 'adv_stream'] bitrate increased to: 1600, waiting
07:53:17.476: [rtmp stream: 'adv_stream'] bitrate increased to: 2200, waiting
07:53:47.493: [rtmp stream: 'adv_stream'] bitrate increased to: 2800, waiting
07:54:17.510: [rtmp stream: 'adv_stream'] bitrate increased to: 3400, waiting
07:54:29.961: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:54:29.961: [rtmp stream: 'adv_stream'] bitrate decreased to: 2800
07:54:59.979: [rtmp stream: 'adv_stream'] bitrate increased to: 3400, waiting
07:55:19.607: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:55:19.607: [rtmp stream: 'adv_stream'] bitrate decreased to: 2800
07:55:47.749: [rtmp stream: 'adv_stream'] bitrate decreased to: 2600
07:55:49.218: [rtmp stream: 'adv_stream'] bitrate decreased to: 2400
07:55:50.328: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
07:56:20.345: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
07:56:50.345: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
07:57:20.351: [rtmp stream: 'adv_stream'] bitrate increased to: 2700, waiting
07:57:50.355: [rtmp stream: 'adv_stream'] bitrate increased to: 3300, waiting
07:58:12.837: [rtmp stream: 'adv_stream'] going back to prev bitrate
07:58:12.837: [rtmp stream: 'adv_stream'] bitrate decreased to: 2700
07:58:14.854: [rtmp stream: 'adv_stream'] bitrate decreased to: 2600
07:58:15.883: [rtmp stream: 'adv_stream'] bitrate decreased to: 2300
07:58:45.895: [rtmp stream: 'adv_stream'] bitrate increased to: 2900, waiting
07:59:15.897: [rtmp stream: 'adv_stream'] bitrate increased to: 3500, waiting
07:59:21.514: [rtmp stream: 'adv_stream'] bitrate decreased to: 3300
07:59:22.521: [rtmp stream: 'adv_stream'] bitrate decreased to: 400
07:59:52.521: [rtmp stream: 'adv_stream'] bitrate increased to: 1000, waiting
08:00:22.531: [rtmp stream: 'adv_stream'] bitrate increased to: 1600, waiting
08:00:50.992: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
08:00:52.035: [rtmp stream: 'adv_stream'] bitrate decreased to: 600
08:01:22.038: [rtmp stream: 'adv_stream'] bitrate increased to: 1200, waiting
08:01:52.056: [rtmp stream: 'adv_stream'] bitrate increased to: 1800, waiting
08:02:22.058: [rtmp stream: 'adv_stream'] bitrate increased to: 2400, waiting
08:02:52.058: [rtmp stream: 'adv_stream'] bitrate increased to: 3000, waiting
08:03:08.957: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:03:08.957: [rtmp stream: 'adv_stream'] bitrate decreased to: 2400
08:03:09.974: [rtmp stream: 'adv_stream'] bitrate decreased to: 2300
08:03:11.111: [rtmp stream: 'adv_stream'] bitrate decreased to: 1100
08:03:41.124: [rtmp stream: 'adv_stream'] bitrate increased to: 1700, waiting
08:04:11.140: [rtmp stream: 'adv_stream'] bitrate increased to: 2300, waiting
08:04:41.157: [rtmp stream: 'adv_stream'] bitrate increased to: 2900, waiting
08:04:48.690: [rtmp stream: 'adv_stream'] bitrate decreased to: 2700
08:04:49.872: [rtmp stream: 'adv_stream'] bitrate decreased to: 2600
08:04:51.029: [rtmp stream: 'adv_stream'] bitrate decreased to: 1700
08:04:59.487: [rtmp stream: 'adv_stream'] bitrate decreased to: 1600
08:05:19.935: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
08:05:20.734: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
08:05:21.923: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
08:05:51.933: [rtmp stream: 'adv_stream'] bitrate increased to: 1800, waiting
08:06:21.950: [rtmp stream: 'adv_stream'] bitrate increased to: 2400, waiting
08:06:51.955: [rtmp stream: 'adv_stream'] bitrate increased to: 3000, waiting
08:07:21.955: [rtmp stream: 'adv_stream'] bitrate increased to: 3600, waiting
08:07:39.880: [rtmp stream: 'adv_stream'] bitrate decreased to: 3200
08:07:41.248: [rtmp stream: 'adv_stream'] bitrate decreased to: 1700
08:07:42.534: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
08:08:09.792: [rtmp stream: 'adv_stream'] bitrate decreased to: 1000
08:08:14.888: [rtmp stream: 'adv_stream'] bitrate decreased to: 800
08:08:16.789: [rtmp stream: 'adv_stream'] bitrate decreased to: 600
08:08:17.816: [rtmp stream: 'adv_stream'] bitrate decreased to: 300
08:08:47.833: [rtmp stream: 'adv_stream'] bitrate increased to: 900, waiting
08:09:17.851: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
08:09:28.370: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:09:28.370: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
08:09:58.387: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
08:10:01.854: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:10:01.854: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
08:10:18.307: [rtmp stream: 'adv_stream'] bitrate decreased to: 800
08:10:35.353: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
08:11:05.367: [rtmp stream: 'adv_stream'] bitrate increased to: 1300, waiting
08:11:23.837: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:11:23.837: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
08:11:53.852: [rtmp stream: 'adv_stream'] bitrate increased to: 1300, waiting
08:12:23.852: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
08:12:53.868: [rtmp stream: 'adv_stream'] bitrate increased to: 2500, waiting
08:13:23.885: [rtmp stream: 'adv_stream'] bitrate increased to: 3100, waiting
08:13:38.553: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:13:38.553: [rtmp stream: 'adv_stream'] bitrate decreased to: 2500
08:13:39.477: [rtmp stream: 'adv_stream'] bitrate decreased to: 2300
08:13:40.632: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
08:13:53.070: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
08:13:53.985: [rtmp stream: 'adv_stream'] bitrate decreased to: 1100
08:13:55.405: [rtmp stream: 'adv_stream'] bitrate decreased to: 800
08:14:25.424: [rtmp stream: 'adv_stream'] bitrate increased to: 1400, waiting
08:14:55.436: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
08:15:25.455: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
08:15:29.917: [rtmp stream: 'adv_stream'] bitrate decreased to: 2500
08:15:31.100: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
08:15:32.950: [rtmp stream: 'adv_stream'] bitrate decreased to: 400
08:16:02.961: [rtmp stream: 'adv_stream'] bitrate increased to: 1000, waiting
08:16:32.976: [rtmp stream: 'adv_stream'] bitrate increased to: 1600, waiting
08:17:02.976: [rtmp stream: 'adv_stream'] bitrate increased to: 2200, waiting
08:17:32.999: [rtmp stream: 'adv_stream'] bitrate increased to: 2800, waiting
08:17:52.467: [rtmp stream: 'adv_stream'] bitrate decreased to: 2700
08:17:53.291: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
08:18:04.265: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
08:18:05.649: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
08:18:35.659: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
08:19:05.665: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
08:19:34.181: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:19:34.181: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
08:19:35.540: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
08:20:05.539: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
08:20:35.552: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
08:21:05.553: [rtmp stream: 'adv_stream'] bitrate increased to: 3200, waiting
08:21:35.573: [rtmp stream: 'adv_stream'] bitrate increased to: 3800, waiting
08:22:05.585: [rtmp stream: 'adv_stream'] bitrate increased to: 4400, waiting
08:22:33.813: [rtmp stream: 'adv_stream'] bitrate decreased to: 4200
08:22:34.575: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
08:22:38.713: [rtmp stream: 'adv_stream'] bitrate decreased to: 2100
08:22:39.742: [rtmp stream: 'adv_stream'] bitrate decreased to: 1100
08:23:09.758: [rtmp stream: 'adv_stream'] bitrate increased to: 1700, waiting
08:23:39.767: [rtmp stream: 'adv_stream'] bitrate increased to: 2300, waiting
08:24:09.783: [rtmp stream: 'adv_stream'] bitrate increased to: 2900, waiting
08:24:39.812: [rtmp stream: 'adv_stream'] bitrate increased to: 3500, waiting
08:24:56.264: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:24:56.264: [rtmp stream: 'adv_stream'] bitrate decreased to: 2900
08:24:58.635: [rtmp stream: 'adv_stream'] bitrate decreased to: 2800
08:25:07.297: [rtmp stream: 'adv_stream'] bitrate decreased to: 2700
08:25:08.071: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
08:25:38.072: [rtmp stream: 'adv_stream'] bitrate increased to: 1800, waiting
08:26:08.077: [rtmp stream: 'adv_stream'] bitrate increased to: 2400, waiting
08:26:34.540: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
08:26:39.927: [rtmp stream: 'adv_stream'] bitrate decreased to: 2100
08:27:09.943: [rtmp stream: 'adv_stream'] bitrate increased to: 2700, waiting
08:27:39.957: [rtmp stream: 'adv_stream'] bitrate increased to: 3300, waiting
08:28:09.959: [rtmp stream: 'adv_stream'] bitrate increased to: 3900, waiting
08:28:16.459: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:28:16.459: [rtmp stream: 'adv_stream'] bitrate decreased to: 3300
08:28:16.976: [rtmp stream: 'adv_stream'] bitrate decreased to: 3200
08:28:23.565: [rtmp stream: 'adv_stream'] bitrate decreased to: 2800
08:28:36.026: [rtmp stream: 'adv_stream'] bitrate decreased to: 2700
08:28:40.657: [rtmp stream: 'adv_stream'] bitrate decreased to: 2600
08:28:41.726: [rtmp stream: 'adv_stream'] bitrate decreased to: 600
08:29:11.742: [rtmp stream: 'adv_stream'] bitrate increased to: 1200, waiting
08:29:28.311: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:29:28.311: [rtmp stream: 'adv_stream'] bitrate decreased to: 600
08:29:58.317: [rtmp stream: 'adv_stream'] bitrate increased to: 1200, waiting
08:30:28.335: [rtmp stream: 'adv_stream'] bitrate increased to: 1800, waiting
08:30:58.350: [rtmp stream: 'adv_stream'] bitrate increased to: 2400, waiting
08:31:28.350: [rtmp stream: 'adv_stream'] bitrate increased to: 3000, waiting
08:31:58.368: [rtmp stream: 'adv_stream'] bitrate increased to: 3600, waiting
08:32:28.377: [rtmp stream: 'adv_stream'] bitrate increased to: 4200, waiting
08:32:47.156: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:32:47.156: [rtmp stream: 'adv_stream'] bitrate decreased to: 3600
08:32:48.033: [rtmp stream: 'adv_stream'] bitrate decreased to: 3400
08:32:49.056: [rtmp stream: 'adv_stream'] bitrate decreased to: 1800
08:32:50.356: [rtmp stream: 'adv_stream'] bitrate decreased to: 1600
08:32:52.910: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
08:33:22.913: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
08:33:52.925: [rtmp stream: 'adv_stream'] bitrate increased to: 2500, waiting
08:34:22.929: [rtmp stream: 'adv_stream'] bitrate increased to: 3100, waiting
08:34:52.934: [rtmp stream: 'adv_stream'] bitrate increased to: 3700, waiting
08:35:22.936: [rtmp stream: 'adv_stream'] bitrate increased to: 4300, waiting
08:35:52.938: [rtmp stream: 'adv_stream'] bitrate increased to: 4900, waiting
08:36:18.363: [rtmp stream: 'adv_stream'] bitrate decreased to: 4700
08:36:19.301: [rtmp stream: 'adv_stream'] bitrate decreased to: 1600
08:36:26.955: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
08:36:35.412: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
08:36:36.232: [rtmp stream: 'adv_stream'] bitrate decreased to: 1100
08:36:37.471: [rtmp stream: 'adv_stream'] bitrate decreased to: 1000
08:36:38.893: [rtmp stream: 'adv_stream'] bitrate decreased to: 400
08:37:08.894: [rtmp stream: 'adv_stream'] bitrate increased to: 1000, waiting
08:37:37.843: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:37:37.843: [rtmp stream: 'adv_stream'] bitrate decreased to: 400
08:38:07.853: [rtmp stream: 'adv_stream'] bitrate increased to: 1000, waiting
08:38:37.853: [rtmp stream: 'adv_stream'] bitrate increased to: 1600, waiting
08:39:07.869: [rtmp stream: 'adv_stream'] bitrate increased to: 2200, waiting
08:39:37.886: [rtmp stream: 'adv_stream'] bitrate increased to: 2800, waiting
08:40:00.508: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:40:00.508: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
08:40:09.083: [rtmp stream: 'adv_stream'] bitrate decreased to: 2100
08:40:12.735: [rtmp stream: 'adv_stream'] bitrate decreased to: 2000
08:40:42.735: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
08:41:12.743: [rtmp stream: 'adv_stream'] bitrate increased to: 3200, waiting
08:41:19.851: [rtmp stream: 'adv_stream'] bitrate decreased to: 3000
08:41:21.095: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
08:41:51.109: [rtmp stream: 'adv_stream'] bitrate increased to: 1800, waiting
08:42:21.134: [rtmp stream: 'adv_stream'] bitrate increased to: 2400, waiting
08:42:51.136: [rtmp stream: 'adv_stream'] bitrate increased to: 3000, waiting
08:43:21.156: [rtmp stream: 'adv_stream'] bitrate increased to: 3600, waiting
08:43:41.550: [rtmp stream: 'adv_stream'] bitrate decreased to: 3500
08:43:42.767: [rtmp stream: 'adv_stream'] bitrate decreased to: 3100
08:43:45.926: [rtmp stream: 'adv_stream'] bitrate decreased to: 2600
08:43:47.000: [rtmp stream: 'adv_stream'] bitrate decreased to: 2500
08:43:48.242: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
08:43:50.742: [rtmp stream: 'adv_stream'] bitrate decreased to: 1700
08:43:52.700: [rtmp stream: 'adv_stream'] bitrate decreased to: 50
08:44:22.721: [rtmp stream: 'adv_stream'] bitrate increased to: 650, waiting
08:44:52.749: [rtmp stream: 'adv_stream'] bitrate increased to: 1250, waiting
08:45:22.751: [rtmp stream: 'adv_stream'] bitrate increased to: 1850, waiting
08:45:52.765: [rtmp stream: 'adv_stream'] bitrate increased to: 2450, waiting
08:46:13.915: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:46:13.915: [rtmp stream: 'adv_stream'] bitrate decreased to: 1850
08:46:17.898: [rtmp stream: 'adv_stream'] bitrate decreased to: 1700
08:46:18.988: [rtmp stream: 'adv_stream'] bitrate decreased to: 1300
08:46:19.995: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
08:46:21.006: [rtmp stream: 'adv_stream'] bitrate decreased to: 600
08:46:51.014: [rtmp stream: 'adv_stream'] bitrate increased to: 1200, waiting
08:47:21.014: [rtmp stream: 'adv_stream'] bitrate increased to: 1800, waiting
08:47:51.030: [rtmp stream: 'adv_stream'] bitrate increased to: 2400, waiting
08:48:21.038: [rtmp stream: 'adv_stream'] bitrate increased to: 3000, waiting
08:48:35.815: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:48:35.815: [rtmp stream: 'adv_stream'] bitrate decreased to: 2400
08:48:37.456: [rtmp stream: 'adv_stream'] bitrate decreased to: 2300
08:48:39.147: [rtmp stream: 'adv_stream'] bitrate decreased to: 2200
08:48:47.596: [rtmp stream: 'adv_stream'] bitrate decreased to: 2100
08:48:52.535: [rtmp stream: 'adv_stream'] bitrate decreased to: 1800
08:48:53.568: [rtmp stream: 'adv_stream'] bitrate decreased to: 800
08:48:56.338: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
08:48:58.346: [rtmp stream: 'adv_stream'] bitrate decreased to: 600
08:49:28.363: [rtmp stream: 'adv_stream'] bitrate increased to: 1200, waiting
08:49:58.371: [rtmp stream: 'adv_stream'] bitrate increased to: 1800, waiting
08:50:28.387: [rtmp stream: 'adv_stream'] bitrate increased to: 2400, waiting
08:50:58.395: [rtmp stream: 'adv_stream'] bitrate increased to: 3000, waiting
08:51:17.078: [rtmp stream: 'adv_stream'] bitrate decreased to: 2900
08:51:18.204: [rtmp stream: 'adv_stream'] bitrate decreased to: 2800
08:51:19.145: [rtmp stream: 'adv_stream'] bitrate decreased to: 50
08:51:49.145: [rtmp stream: 'adv_stream'] bitrate increased to: 650, waiting
08:52:19.156: [rtmp stream: 'adv_stream'] bitrate increased to: 1250, waiting
08:52:25.604: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:52:25.604: [rtmp stream: 'adv_stream'] bitrate decreased to: 650
08:52:55.611: [rtmp stream: 'adv_stream'] bitrate increased to: 1250, waiting
08:53:25.627: [rtmp stream: 'adv_stream'] bitrate increased to: 1850, waiting
08:53:55.627: [rtmp stream: 'adv_stream'] bitrate increased to: 2450, waiting
08:54:25.636: [rtmp stream: 'adv_stream'] bitrate increased to: 3050, waiting
08:54:50.643: [rtmp stream: 'adv_stream'] going back to prev bitrate
08:54:50.643: [rtmp stream: 'adv_stream'] bitrate decreased to: 2450
08:54:54.435: [rtmp stream: 'adv_stream'] bitrate decreased to: 2300
08:54:55.464: [rtmp stream: 'adv_stream'] bitrate decreased to: 500
08:55:25.476: [rtmp stream: 'adv_stream'] bitrate increased to: 1100, waiting
08:55:55.480: [rtmp stream: 'adv_stream'] bitrate increased to: 1700, waiting
08:56:07.939: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
08:56:37.952: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
08:57:07.958: [rtmp stream: 'adv_stream'] bitrate increased to: 2700, waiting
08:57:37.958: [rtmp stream: 'adv_stream'] bitrate increased to: 3300, waiting
08:58:07.968: [rtmp stream: 'adv_stream'] bitrate increased to: 3900, waiting
08:58:20.958: [rtmp stream: 'adv_stream'] bitrate decreased to: 3400
08:58:21.924: [rtmp stream: 'adv_stream'] bitrate decreased to: 2800
08:58:28.391: [rtmp stream: 'adv_stream'] bitrate decreased to: 2600
08:58:30.097: [rtmp stream: 'adv_stream'] bitrate decreased to: 600
08:59:00.116: [rtmp stream: 'adv_stream'] bitrate increased to: 1200, waiting
08:59:30.128: [rtmp stream: 'adv_stream'] bitrate increased to: 1800, waiting
09:00:00.129: [rtmp stream: 'adv_stream'] bitrate increased to: 2400, waiting
09:00:30.138: [rtmp stream: 'adv_stream'] bitrate increased to: 3000, waiting
09:00:42.578: [rtmp stream: 'adv_stream'] bitrate decreased to: 2700
09:00:43.357: [rtmp stream: 'adv_stream'] bitrate decreased to: 2500
09:00:44.514: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
09:00:45.986: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
09:01:16.001: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
09:01:24.672: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
09:01:54.685: [rtmp stream: 'adv_stream'] bitrate increased to: 2000, waiting
09:02:24.699: [rtmp stream: 'adv_stream'] bitrate increased to: 2600, waiting
09:02:54.705: [rtmp stream: 'adv_stream'] bitrate increased to: 3200, waiting
09:03:24.726: [rtmp stream: 'adv_stream'] bitrate increased to: 3800, waiting
09:03:33.173: [rtmp stream: 'adv_stream'] bitrate decreased to: 3700
09:03:43.821: [rtmp stream: 'adv_stream'] bitrate decreased to: 3200
09:04:13.837: [rtmp stream: 'adv_stream'] bitrate increased to: 3800, waiting
09:04:43.849: [rtmp stream: 'adv_stream'] bitrate increased to: 4400, waiting
09:04:44.304: [rtmp stream: 'adv_stream'] bitrate decreased to: 3800
09:04:45.149: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
09:05:15.153: [rtmp stream: 'adv_stream'] bitrate increased to: 1300, waiting
09:05:25.617: [rtmp stream: 'adv_stream'] going back to prev bitrate
09:05:25.617: [rtmp stream: 'adv_stream'] bitrate decreased to: 700
09:05:55.620: [rtmp stream: 'adv_stream'] bitrate increased to: 1300, waiting
09:06:25.629: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
09:06:55.641: [rtmp stream: 'adv_stream'] bitrate increased to: 2500, waiting
09:07:25.641: [rtmp stream: 'adv_stream'] bitrate increased to: 3100, waiting
09:07:55.654: [rtmp stream: 'adv_stream'] bitrate increased to: 3700, waiting
09:08:04.109: [rtmp stream: 'adv_stream'] going back to prev bitrate
09:08:04.109: [rtmp stream: 'adv_stream'] bitrate decreased to: 3100
09:08:05.152: [rtmp stream: 'adv_stream'] bitrate decreased to: 2900
09:08:06.338: [rtmp stream: 'adv_stream'] bitrate decreased to: 1200
09:08:07.685: [rtmp stream: 'adv_stream'] bitrate decreased to: 500
09:08:37.685: [rtmp stream: 'adv_stream'] bitrate increased to: 1100, waiting
09:09:07.685: [rtmp stream: 'adv_stream'] bitrate increased to: 1700, waiting
09:09:21.801: [rtmp stream: 'adv_stream'] going back to prev bitrate
09:09:21.801: [rtmp stream: 'adv_stream'] bitrate decreased to: 1100
09:09:51.817: [rtmp stream: 'adv_stream'] bitrate increased to: 1700, waiting
09:09:58.277: [rtmp stream: 'adv_stream'] bitrate decreased to: 1600
09:10:01.060: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
09:10:02.823: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
09:10:32.823: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
09:11:02.833: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
09:11:19.283: [rtmp stream: 'adv_stream'] going back to prev bitrate
09:11:19.283: [rtmp stream: 'adv_stream'] bitrate decreased to: 1500
09:11:21.373: [rtmp stream: 'adv_stream'] bitrate decreased to: 1400
09:11:22.715: [rtmp stream: 'adv_stream'] bitrate decreased to: 600
09:11:24.014: [rtmp stream: 'adv_stream'] bitrate decreased to: 100
09:11:54.027: [rtmp stream: 'adv_stream'] bitrate increased to: 700, waiting
09:12:24.042: [rtmp stream: 'adv_stream'] bitrate increased to: 1300, waiting
09:12:54.049: [rtmp stream: 'adv_stream'] bitrate increased to: 1900, waiting
09:13:24.062: [rtmp stream: 'adv_stream'] bitrate increased to: 2500, waiting
09:13:54.078: [rtmp stream: 'adv_stream'] bitrate increased to: 3100, waiting
09:14:24.098: [rtmp stream: 'adv_stream'] bitrate increased to: 3700, waiting
09:14:54.103: [rtmp stream: 'adv_stream'] bitrate increased to: 4300, waiting
09:15:24.111: [rtmp stream: 'adv_stream'] bitrate increased to: 4900, waiting
09:15:54.127: [rtmp stream: 'adv_stream'] bitrate increased to: 5500, waiting
09:16:24.137: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
09:24:40.576: [rtmp stream: 'adv_stream'] bitrate decreased to: 5800
09:24:41.359: [rtmp stream: 'adv_stream'] bitrate decreased to: 3600
09:25:11.359: [rtmp stream: 'adv_stream'] bitrate increased to: 4200, waiting
09:25:41.375: [rtmp stream: 'adv_stream'] bitrate increased to: 4800, waiting
09:26:11.375: [rtmp stream: 'adv_stream'] bitrate increased to: 5400, waiting
09:26:41.384: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
09:57:05.809: [rtmp stream: 'adv_stream'] bitrate decreased to: 5900
09:57:30.272: [rtmp stream: 'adv_stream'] bitrate decreased to: 5800
09:57:38.372: [rtmp stream: 'adv_stream'] bitrate decreased to: 5700
09:58:00.839: [rtmp stream: 'adv_stream'] bitrate decreased to: 5500
09:58:30.843: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
09:59:03.552: [rtmp stream: 'adv_stream'] going back to prev bitrate
09:59:03.552: [rtmp stream: 'adv_stream'] bitrate decreased to: 5500
09:59:03.847: [rtmp stream: 'adv_stream'] bitrate decreased to: 5300
09:59:33.849: [rtmp stream: 'adv_stream'] bitrate increased to: 5900, waiting
09:59:40.288: [rtmp stream: 'adv_stream'] bitrate decreased to: 5800
09:59:47.287: [rtmp stream: 'adv_stream'] bitrate decreased to: 5700
10:00:17.300: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
10:01:00.765: [rtmp stream: 'adv_stream'] bitrate decreased to: 5500
10:01:01.887: [rtmp stream: 'adv_stream'] bitrate decreased to: 900
10:01:31.887: [rtmp stream: 'adv_stream'] bitrate increased to: 1500, waiting
10:02:01.891: [rtmp stream: 'adv_stream'] bitrate increased to: 2100, waiting
10:02:31.899: [rtmp stream: 'adv_stream'] bitrate increased to: 2700, waiting
10:03:01.906: [rtmp stream: 'adv_stream'] bitrate increased to: 3300, waiting
10:03:31.927: [rtmp stream: 'adv_stream'] bitrate increased to: 3900, waiting
10:04:01.944: [rtmp stream: 'adv_stream'] bitrate increased to: 4500, waiting
10:04:31.952: [rtmp stream: 'adv_stream'] bitrate increased to: 5100, waiting
10:05:01.953: [rtmp stream: 'adv_stream'] bitrate increased to: 5700, waiting
10:05:31.967: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
10:37:32.415: [rtmp stream: 'adv_stream'] bitrate decreased to: 5900
10:38:02.432: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
10:38:50.898: [rtmp stream: 'adv_stream'] bitrate decreased to: 5900
10:39:20.914: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
10:39:31.373: [rtmp stream: 'adv_stream'] bitrate decreased to: 5800
10:40:01.382: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
10:41:17.863: [rtmp stream: 'adv_stream'] going back to prev bitrate
10:41:17.863: [rtmp stream: 'adv_stream'] bitrate decreased to: 5800
10:41:18.013: [rtmp stream: 'adv_stream'] bitrate decreased to: 5700
10:41:48.025: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
11:10:06.447: [rtmp stream: 'adv_stream'] going back to prev bitrate
11:10:06.447: [rtmp stream: 'adv_stream'] bitrate decreased to: 5700
11:10:36.455: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
11:10:48.899: [rtmp stream: 'adv_stream'] bitrate decreased to: 5600
11:11:18.912: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
14:02:37.338: [rtmp stream: 'adv_stream'] going back to prev bitrate
14:02:37.338: [rtmp stream: 'adv_stream'] bitrate decreased to: 5600
14:02:41.788: [rtmp stream: 'adv_stream'] bitrate decreased to: 5500
14:03:11.794: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
14:03:23.115: [rtmp stream: 'adv_stream'] bitrate decreased to: 5800
14:03:53.136: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
14:04:19.594: [rtmp stream: 'adv_stream'] going back to prev bitrate
14:04:19.594: [rtmp stream: 'adv_stream'] bitrate decreased to: 5800
14:04:19.849: [rtmp stream: 'adv_stream'] bitrate decreased to: 5200
14:04:49.860: [rtmp stream: 'adv_stream'] bitrate increased to: 5800, waiting
14:05:19.860: [rtmp stream: 'adv_stream'] bitrate increased to: 6000, done
am 24.01.2022 21:27
Hallo EdvonSchleck,
mit diesen Logs können wir und der Folgebereich nichts anfangen. Beim Rückweg gibt es keine größeren Einschränkungen. Anhand der Speedtests sieht es so aus, als wären die Probleme unter der Woche meistens zwischen 20 und 0 Uhr, deckt sich das mit Deinen Beobachtungen?
24.01.2022 22:35 - bearbeitet 24.01.2022 22:38
Korrekt aber auch zu anderen Uhrzeiten.
Was halt auffällt ist dass die Probleme praktisch nicht exisitieren wenn alle QAMwerte bei 64 sind. Ist mehr als ein Kanal auf 32 oder weniger runter fangen die Probleme an.
Mitten in der Nacht auch mal um Uhrzeiten wie um 3:57 Uhr kann das passieren und dann spinnt der Upload. Denke kaum dass zu der Uhrzeit das Segment/Node überlastet ist.
Heute übrigens wieder im Zeitbereich von 20:55 bis 22:28
22:28:01.109: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 37060 (11.1%)
Das heißt für 11.1% der Zeit bringt die Leitung nicht mal 6392 Kbps stabil auf die Reihe.
20:55:40.652: ==== Streaming Start ===============================================
22:28:01.109: [rtmp stream: 'adv_stream'] User stopped the stream
22:28:01.109: [rtmp stream: 'adv_stream'] Socket send buffer is 65536 bytes
22:28:01.109: socket_thread_windows: Normal exit
22:28:01.109: Output 'adv_stream': stopping
22:28:01.109: Output 'adv_stream': Total frames output: 295349 (332409 attempted)
22:28:01.109: Output 'adv_stream': Total drawn frames: 332320 (332496 attempted)
22:28:01.109: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 176 (0.1%)
22:28:01.110: Video stopped, number of skipped frames due to encoding lag: 199/332430 (0.1%)
22:28:01.112: ==== Streaming Stop ================================================
am 25.01.2022 16:20
Heute 16 Uhr zwei Kanäle auf 32 QAM runter und die Probleme gehen wieder los.
25.01.2022 16:46 - bearbeitet 25.01.2022 16:52
Dass ihr das nicht seht ist für mich unverständlich.
