Kein Internet !!
cip
Kann mir bitte jemand erklären, was das bedeutet!!
/2022 20:53:40 DISASSOC - MAC=3e:38:bc:d4:b3:80, Reason=34; WG-MAC=F0:AF:85:A5:CD:43; IF=wlan1_0 Wi-Fi 12/16/2022 20:53:36 REASON-CODE-DESCR=PREV_AUTH_NOT_VALID;REASON-CODE=2; WG-MAC=F0:AF:85:A5:CD:43; STA-MAC=3e:38:bc:d4:b3:80; IF=wlan1_0; SSID=Vodafone-E9B7; ConnectionState=forcedDisassociatedAuth; WirelessMode=802.11ac; LastTxPhyRate=234Mbps; LastRxPhyRate=58Mbps; MaxSupportedRate:866Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-71dBm; Channel=5280MHz; Radio=5G; Bandwidth=80M; TxFailPkts=0; RetransPkts=22 Wi-Fi 12/16/2022 20:53:34 WG-MAC=F0:AF:85:A5:CD:42; STA-MAC=3e:38:bc:d4:b3:80; IF=wlan0_0; SSID=Vodafone-E9B7; ConnectionState=connected; WirelessMode=802.11n; LastTxPhyRate=39Mbps; LastRxPhyRate=6Mbps; MaxSupportedRate:150Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-64dBm; Channel=2437MHz; Radio=2.4G; Bandwidth=20M; TxFailPkts=0; RetransPkts=0 Wi-Fi 12/16/2022 20:53:34 MAC 3e:38:bc:d4:b3:80 associated to Vodafone-E9B7; WG-MAC=F0:AF:85:A5:CD:42; IF=wlan0_0 Wi-Fi 12/16/2022 20:53:34 MAC 3e:38:bc:d4:b3:80 authentication with Vodafone-E9B7; WG-MAC=F0:AF:85:A5:CD:42; IF=wlan0_0 Wi-Fi 12/16/2022 20:52:31 DISASSOC - MAC=3e:38:bc:d4:b3:80, Reason=34; WG-MAC=F0:AF:85:A5:CD:42; IF=wlan0_0 Wi-Fi 12/16/2022 20:52:27 REASON-CODE-DESCR=PREV_AUTH_NOT_VALID;REASON-CODE=2; WG-MAC=F0:AF:85:A5:CD:42; STA-MAC=3e:38:bc:d4:b3:80; IF=wlan0_0; SSID=Vodafone-E9B7; ConnectionState=forcedDisassociatedAuth; WirelessMode=802.11n; LastTxPhyRate=6Mbps; LastRxPhyRate=65Mbps; MaxSupportedRate:300Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-65dBm; Channel=2437MHz; Radio=2.4G; Bandwidth=20M; TxFailPkts=0; RetransPkts=146 Wi-Fi 12/16/2022 20:52:27 WG-MAC=F0:AF:85:A5:CD:43; STA-MAC=3e:38:bc:d4:b3:80; IF=wlan1_0; SSID=Vodafone-E9B7; ConnectionState=connected; WirelessMode=802.11ac; LastTxPhyRate=234Mbps; LastRxPhyRate=6Mbps; MaxSupportedRate:866Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-72dBm; Channel=5280MHz; Radio=5G; Bandwidth=80M; TxFailPkts=0; RetransPkts=0 Wi-Fi 12/16/2022 20:52:27 MAC 3e:38:bc:d4:b3:80 associated to Vodafone-E9B7; WG-MAC=F0:AF:85:A5:CD:43; IF=wlan1_0 Wi-Fi 12/16/2022 20:52:27 MAC 3e:38:bc:d4:b3:80 authentication with Vodafone-E9B7; WG-MAC=F0:AF:85:A5:CD:43; IF=wlan1_0 Wi-Fi 12/16/2022 20:26:47 DISASSOC - MAC=3e:38:bc:d4:b3:80, Reason=34; WG-MAC=F0:AF:85:A5:CD:43; IF=wlan1_0 Wi-Fi 12/16/2022 20:26:43 REASON-CODE-DESCR=PREV_AUTH_NOT_VALID;REASON-CODE=2; WG-MAC=F0:AF:85:A5:CD:43; STA-MAC=3e:38:bc:d4:b3:80; IF=wlan1_0; SSID=Vodafone-E9B7; ConnectionState=forcedDisassociatedAuth; WirelessMode=802.11ac; LastTxPhyRate=117Mbps; LastRxPhyRate=26Mbps; MaxSupportedRate:866Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-79dBm; Channel=5280MHz; Radio=5G; Bandwidth=80M; TxFailPkts=0; RetransPkts=190 W
8 Antworten 8
Menne99
mach nen Screenshot, das kann keiner lesen!
Der glubb is a Depp
cip
Arbeiten Sie nicht, um einen Screenshot hier!!!
hier ist ein Kunden helfen Kunden Forum, wenn du Hilfe willst , dann helf den Lesern dir zu helfen , oder nimm die Kontakte von VF ,Whatsapp, Twitter, Hotline , Facebook
Der glubb is a Depp
cip
Das Team von vodafone schickt mich in dieses Forum!!  u schick mich ihnen zurück ... ist schon zu viel!! Ich glaube, ich habe endlich ein Bild gemacht, das ich hierher schicken kann!
Was soll ich machen wir sind alles nur Kunden und seit August 22 ist hier kein Mod mehr da der richtig helfen kann , guck, mal unter Docsis Status , und mache davon nen Screenshot
Der glubb is a Depp
cip
Vielen Dank für Ihre schnelle Antwort und Ihre Zeit, mir zu helfen! Für mich ist es nicht gut, dass ich seit 3 Wochen kein Internet mehr habe, also sorry für meinen Mangel an Geduld!
schau ob der Verstärker Strom hat, ob das Koaxkabel von der Dose zur VF Box fest sitzt , ob der Innenleiter von dem Koaxkabel evtl gebrochen ist, muss solange sein wie das Gewinde von der Mutter, evtl ist ein Dosenaufsatz verbaut, sitzt der richtig, geht beim Nachbarn, und wenn das nicht hilft Whatsapp, Twitter, Facebook
Der glubb is a Depp
cip
Ok, vielen Dank für Ihre Hilfe, Ich werde das tun!! Ich wünsche mir ein frohes Weihnachtsfest!
