am 29.06.2022 10:24
Hello,
I have been having several disruptions in the internet connections. I have 250/25 Mbps cable internet connection. The internet speed seems to drop to very few Mbs at times. I have met with call disruptions in my work. I work from home and such disturbances are too bad while on a call with my team. Some times the download speed drops and at other times the upload speed drops. The problem is very momentary but it is highly annoying. The images cannot really justify the problem I got. Even web pages do not load. I have tried resetting the router, cleared cache and restarted my system.
29.06.2022 11:02 - bearbeitet 29.06.2022 11:03
Bitte beantworte:
Poste bitte den kompletten Docsis Pegel, also – Empfangs- und Senderichtung – als Foto 4tes Icon von rechts.
am 29.06.2022 11:03
Please do tests only using a wired connection.
You may experience interruptions and/or slow speeds of your connection due to interference with other WiFi networks and the building structure if you test using WiFi.
