Cisco Webex funktioniert nicht
BobNow
chlau@muc-mpdvk ~ % ping akamai.webex.com
PING global-nebulaie.webex.com (66.114.168.199): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
^C
--- global-nebulaie.webex.com ping statistics ---
3 packets transmitted, 0 packets received, 100.0% packet loss
chlau@muc-mpdvk ~ % traceroute akamai.webex.com
traceroute to global-nebulaie.webex.com (66.114.168.199), 64 hops max, 52 byte packets
1  rt-ax92u-e2b0 (192.168.50.1)  1.492 ms  2.147 ms  1.557 ms
2  compalhub.home (192.168.0.1)  2.093 ms  1.996 ms  1.993 ms
3  ip53a9b746.static.kabel-deutschland.de (83.169.183.70)  11.880 ms  16.042 ms  17.096 ms
4  ip5886cad9.static.kabel-deutschland.de (88.134.202.217)  15.118 ms
    ip5886caa5.static.kabel-deutschland.de (88.134.202.165)  18.276 ms  17.109 ms
5  145.254.3.102 (145.254.3.102)  16.269 ms
    145.254.3.100 (145.254.3.100)  10.473 ms
    145.254.3.102 (145.254.3.102)  15.012 ms
6  145.254.2.181 (145.254.2.181)  14.828 ms
    145.254.2.175 (145.254.2.175)  13.526 ms  22.702 ms
7  ae4-100-xcr1.mue.cw.net (195.2.5.13)  15.707 ms  12.174 ms  18.751 ms
8  ae10.pcr1.fis.cw.net (195.2.18.182)  101.541 ms  98.284 ms  99.540 ms
9  ae37-pcr1.ptl.cw.net (195.2.16.230)  97.613 ms  105.947 ms  102.432 ms
10  et-7-1-0-xcr1.nyh.cw.net (195.2.24.241)  102.660 ms  95.751 ms  98.048 ms
11  ae13-xcr2.nyk.cw.net (195.2.25.69)  107.690 ms  98.700 ms  110.093 ms
12  lumen-gw-xcr2.nyk.cw.net (195.2.26.30)  100.220 ms  97.610 ms  98.730 ms
13  * * *
14  *
es funktioniert für meinen Nachbarn
C:\tmp>tracert akamai.webex.com
Tracing route to global-nebulaie.webex.com[66.114.168.199]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms 192.168.10.1
2 1 ms 2 ms 1 ms 192.168.1.1
3 11 ms 13 ms 11 ms ipbcc0d0fe.dynamic.kabel-deutschland.de[188.192.208.254]
4 13 ms 17 ms 12 ms ip5886de86.static.kabel-deutschland.de[88.134.222.134]
5 56 ms 14 ms 24 ms ip5886bbb0.dynamic.kabel-deutschland.de[88.134.187.176]
6 13 ms 14 ms 28 ms 145.254.3.102
7 12 ms 14 ms 15 ms 145.254.2.181
8 9 ms 10 ms 14 ms ae4-100-xcr1.mue.cw.net[195.2.5.13]
9 96 ms 95 ms 101 ms ae10.pcr1.fis.cw.net[195.2.18.182]
10 110 ms 97 ms 104 ms ae37-pcr1.ptl.cw.net[195.2.16.230]
11 98 ms 101 ms 98 ms et-7-1-0-xcr1.nyh.cw.net[195.2.24.241]
12 96 ms 99 ms 97 ms ae13-xcr2.nyk.cw.net[195.2.25.69]
13 96 ms 99 ms 107 ms lumen-gw-xcr2.nyk.cw.net[195.2.26.30]
14 141 ms 143 ms 98 ms CISCO-SYSTE.ear1.NewYork6.Level3.net[4.30.178.246]
15 * * * Request timed out.
16 102 ms 97 ms 97 ms jfk10-wxbb-crt02-bu60.webex.com[64.68.116.46]
17 114 ms 102 ms 99 ms 64.68.118.32
18 116 ms 102 ms 103 ms iad02-wxbb-crt02-be103.webex.com[64.68.117.219]
19 101 ms 105 ms 101 ms iad02-wxbb-crt01-bu10.webex.com[64.68.117.173]
20 135 ms 138 ms 133 ms dfw10-wxbb-crt01-be103.webex.com[64.68.117.217]
21 169 ms 170 ms 169 ms sjc02-wxbb-crt01-hu0-2-0-0.webex.com[64.68.116.33]
22 168 ms 169 ms 168 ms sjc02-wxbb-pe02-bu12.webex.com[64.68.117.121]
23 171 ms 170 ms 177 ms sjc02-wxp00-gw02-po522-100.webex.com[209.197.223.167]
24 * * * Request timed out.
25 169 ms 167 ms 168 ms global-nebulaie.webex.com[66.114.168.199]
Trace complete.
C:\tmp>ping https://akamai.webex.com
Pinging https://global-nebulaie.webex.com[https://66.114.168.199] with 32 bytes of data:
Reply from https://66.114.168.199: bytes=32 time=303ms TTL=237
Reply from https://66.114.168.199: bytes=32 time=168ms TTL=237
Ping statistics for https://66.114.168.199:
Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 168ms, Maximum = 303ms, Average = 235ms
Ex-Moderator:in
Ex-Moderator:in
Hi @BobNow,
n paar mehr Infos wäre schön. Welche? Das findest Du in diesem Beitrag 😉
Danke
es funktioniert heute
64 bytes from 66.114.168.199: icmp_seq=0 ttl=236 time=306.953 ms
64 bytes from 66.114.168.199: icmp_seq=1 ttl=236 time=224.087 ms
^C
2 packets transmitted, 2 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 224.087/265.520/306.953/41.433 ms
1  rt-ax92u-e2b0 (192.168.50.1)  1.780 ms  1.072 ms  1.052 ms
2  compalhub.home (192.168.0.1)  1.981 ms  1.984 ms  1.917 ms
3  ip53a9b746.static.kabel-deutschland.de (83.169.183.70)  11.498 ms  12.797 ms  10.769 ms
4  ip5886caa5.static.kabel-deutschland.de (88.134.202.165)  11.706 ms
    ip5886cad9.static.kabel-deutschland.de (88.134.202.217)  12.314 ms  10.856 ms
5  145.254.3.100 (145.254.3.100)  12.209 ms
    145.254.3.102 (145.254.3.102)  12.814 ms
    145.254.3.100 (145.254.3.100)  10.717 ms
6  145.254.2.175 (145.254.2.175)  14.652 ms
    145.254.2.181 (145.254.2.181)  10.850 ms  19.973 ms
7  ae4-100-xcr1.mue.cw.net (195.2.5.13)  10.980 ms  14.749 ms  12.523 ms
8  ae10.pcr1.fis.cw.net (195.2.18.182)  98.391 ms  106.496 ms  97.990 ms
9  ae37-pcr1.ptl.cw.net (195.2.16.230)  97.778 ms  97.853 ms  99.786 ms
10  et-7-1-0-xcr1.nyh.cw.net (195.2.24.241)  100.162 ms  105.864 ms  96.102 ms
11  ae13-xcr2.nyk.cw.net (195.2.25.69)  104.537 ms  96.179 ms  96.928 ms
12  lumen-gw-xcr2.nyk.cw.net (195.2.26.30)  95.943 ms  101.081 ms  96.800 ms
13  *akamai.webex.com * *
14  * * *
15  * * *
16  * * *
17  * * *
Ex-Moderator:in
Ex-Moderator:in
Hallo BobNow,
also ist mit Cisco Webex nun wieder alles in Ordnung? Wenn nicht, sende bitte noch die Infos aus dem verlinkten Thread.
