am 01.10.2019 10:49
Earlier the router WiFi signal was very week. From yesterday it has completely stopped the WiFi signal. Now hotspot is not visible. The router might have defected. I don't have internet access. Please help me to solve this issue.
am 01.10.2019 16:54
Hi Amit1,
I'm not sure. Do you have an own router or do you mean an ordinary hotspot?
Kind regards
am 06.10.2019 17:45
Hello,
The WiFi Router is provided by the Vodafone. LAN is working fine. No problem with the internet connection. Router's hotspot signal too low. I can get the signal only when I take the device very close (0.5 meter). It needs replacement. Can you please suggest what should be done to get the router replaced? Attached the router type.
Regards,
Amit
am 08.10.2019 08:30
Hi Amit,
Which router (model) do you have from us? Can you please perform a factory reset with the router?
Regards
Wallace
am 08.10.2019 13:19
Hello,
I have HITRON CVE-30360 router. I did factory reset, but nothing changed. Routers signal emitting capacity has been reduced. I think it needs replacement.
Thanks,
Amit
am 10.10.2019 12:16
Hi Amit,
I like to change the router. Send me your customer data (name, address, birthday, customer number) in a private message and then let me know that you have transmitted the data.
Regards
Wallace
am 10.10.2019 19:05
Hello Wallace,
I have sent details in private mail.
Thanks,
Amit
am 14.10.2019 13:04
Hello, Amit1,
I initiated the exchange. Please send us feedback after the device has been replaced. The defective router must be returned to us.
Best regards Fred
am 20.10.2019 06:03
Hello,
Thanks for initiating the replacement.
I stay alone in house. House will be locked during my office hours. How can I know when will the technician come to house? or is there possibility to have technician come to house for replacement at specific time?
Thanks,
Amit
am 29.10.2019 00:00
Hello,
It's been two weeks, nobody come to replace the router. Could you please let me know the status?
Thanks
Amit
