Menu Toggle
Aktuelle Einschränkungen:
Mobil: Mobile Daten&Telefonie 3G & 4G & 5G im Bereich Unna, Kamen, Holzwicke, Werl
Mobil: Behoben: Mobile Telefonie u. Daten 2G/3G/4G im Bereich Hameln, Hessisch Oldendorf, Aerzen, Emmerthal
Mobil: Behoben: Roaming Finnland - Mobile Telefonie
E-Mail: Vodafone E-Mail verzögerter E-Mail Empfang/Abruf
Nähere Informationen dazu findet Ihr im Eilmeldungsboard
Close announcement
WLAN-Hotspots
Siehe neueste
Problem with WLAN
ada3004
Dear Vodafone Team,
I am writing to You regarding my Internet problems.
Let me describe the problem.
First of all, Internet is not very stable on all the devices. It loses connection after using the device for a while.  I use video applications for video conference a lot and it is very annoying as it disconnects. When I use one device connected to the Internet and I want to turn on another device for example a laptop also connected to the same network, automatically the first device loses connection to the Internet. Above problems are very common.
Secondly, I was looking for a solution to the problem on your site. What I found was to disconnect router for 3 minutes and after that problem will be fixed, but nothing happend.
Could You please check Internet traffic, or what is the problem and fix it as soon as posible?
Thank you very much for your help and I look forward for further instructions.
Kind regards
7 Antworten 7
Martin59
Moderator
Hello ada3004,
We will be happy to check what is causing the dropouts. Before that, please answer the questions in which state you live, which router you use and whether the interference also occurs via LAN cable.
Best regards, Martin
#Stayhome und bleibt gesund
Alles Easy How To Hilfe !
ada3004
Hi
I´m living in München. About Router it´s Vodafone Station, CGA4233DE.
I´m not using LAN cable.
Thank You so much.
Moni_GK
Moderatorin
Hello ada3004,
I would be happy to take a look at the line. Please send me a PN with your customer data (name, address, customer number and date of birth).
Please contact me again when you have sent me the data.
Best regards
Moni
Netz-Assistent How To Hilfe !
#bleibtgesund
ada3004
Hi
I´ve alredy sent You my data in PM.
Moni_GK
Moderatorin
Hello ada3004,
The line is absolutely fine.
Have you changed the WLAN channel and is the 2.4 or the 5 GHz WLAN affected?
Greetings Moni
#bleibtgesund
ada3004
Hello,
The WLAN channel has not been changed.
Yes, it applies to 2.4GHz and 5GHz WLAN
Could you please check if my connection is stable enough?
Ada
Wallace
Moderator
According to the system, the 2.4 and 5GHz still have the same SSID (name). Please give both networks their own SSID and then test the networks separately.
Regards
Wallace
