am 17.01.2022 10:20
Hello,
The Kantstrasse 125 hotspot in Berlin has stopped working since Sunday. I can no longer see the wireless network.
I was using it for my work as it was the only one I could receive signal from. There is no longer a signal.
Please fix.
am 19.01.2022 09:02
Hello sotirone,
can you tell us the ID of the spot? Sometimes the spot are provided by customer modems and they can simply turn off the spot.
Best regards Fred
am 19.01.2022 10:03
The hotspot ID: SH-3-491
am 21.01.2022 11:16
Hi sotirone,
I restartet the spot. Please try, if it works now.
Kind regards
am 21.01.2022 13:58
It works now, thank you!
am 24.01.2022 17:57
Hello sotirone,
thank you for feedback, I will close your thread now. You will get a PM with a survey in a few minutes, it would be great if you take part :).
Kind regards,
