am 03.05.2018 18:10
I bought a 30-day ticket on April 16th and it worked for about a week (of course with little problems - it worked 1-2 hours and then 10-20 minutes break) and now it does not work at all.
The Hotspots near me are:
HH-3-3226218
HH-3-3226802
HH-3-3500511
HH-3-3255545
HH-3-3239342
am 28.05.2018 11:23
am 29.05.2018 14:20
Hello lonat1,
I have no idea what happened. Let's just be happy that everything works fine now. 🙂
Shall I close this thread?
Kind regards,
Sebastian
am 23.06.2018 18:56
The problem came back....have you found any solutions?
I bought the ticket for 1 week 2 times and I want to tell you that it went perfectly.
and if everything went smoothly, I said let's buy the month ticket ... I bought the one-month ticket .. and boom ... it worked only one day.
Until now I only had this problem with the one-month vouchers ....
Please restart the following routers maybe that will solve the problem.
Hotspot-ID: HH-3-3500511
HH-3-3255545
HH-3-3226802
HH-3-3239342
am 26.06.2018 11:00
am 26.06.2018 11:30
Hello lonut1,
Unfortunately I can't reset these spots unless the owner tells us to do that. HH-3-3226802 and HH-3-3239342 should be working. There are quite a few connections with several devices.
Kind regards,
Sebastian
am 26.06.2018 17:28
Then restrict my access to those routers that you can not reset (HH-3-3500511 and HH-3-3255545) and tell me what mac address the routers HH-3-3226802 and HH-3-3239342 ... to know on which hotspot to connect. Do you have my mac address in first attachment.
am 28.06.2018 08:06
am 28.06.2018 20:07
Hello Ionut1,
due to data protection we cannot give you any information on the Hotspots. I made a task for the colleagues as suggested last time, they will call you in the next days.
Kind regards
am 03.07.2018 16:27
Please close my access to the router with the following mac address: BE-D9-4D-5C-18-4D
so I may be able to connect to the next router that I hope will work
am 05.07.2018 15:04
Hi lonut1,
I'm a litte bit confused. We can't close your access to the a router. You only have to logut?
Kind regards
Marcus
