Hotspot IPv4
Pablotto
I have no internet access since yesterday. My network card is connecting to the hotspot but no internet access. I think the problem is with the access point and needs to be reset remotely because don't see any IPv4 settings, IP, Gate, DNS, etc. I connect to other hotspot but is to far and the signal is to weak. The nearest hotspot is :
WLAN Name: Vodafone Hotspot
Hotspot ID: HH-2-5992891
I hope this is enough information, thank you in advance.
Identyfikator SSID:	Vodafone Hotspot
Protokół:	Wi-Fi 4 (802.11n)
Typ zabezpieczeń:	Otwarta
Pasmo sieci:	2,4 GHz
Kanał sieci:	3
Szybkość łącza (odbieranie/przesyłanie):	72/72 (Mbps)
Adres IPv6 połączenia lokalnego:	fe80::650b:2458:8755:b202%3
Serwery DNS IPv6:	fec0:0:0:ffff::1%1
			fec0:0:0:ffff::2%1
			fec0:0:0:ffff::3%1
Producent:	Realtek Semiconductor Corp.
Opis:	TP-Link Wireless USB Adapter
Wersja sterownika:	1030.38.712.2019
pRo-Marco
Ex-Moderator:in
Ex-Moderator:in
Hi Pablotto,
there is problem with the signal at the spot. To fix this, the owner of the conract has do contact us. Please use another spot instead.
Kind regards
Pablotto
If I could connect to another hotspot, I wouldn't create this post.
Thanks for nothing.
pRo-Marco
Ex-Moderator:in
Ex-Moderator:in
Hi Pablotto,
there is no entitlement to the use of a particular spot. You can use it when you are on the move, not as a substitute for a fixed connection.
Kind regards
