am 30.04.2021 09:11
Identyfikator SSID: Vodafone Hotspot Protokół: Wi-Fi 4 (802.11n) Typ zabezpieczeń: Otwarta Pasmo sieci: 2,4 GHz Kanał sieci: 3 Szybkość łącza (odbieranie/przesyłanie): 72/72 (Mbps) Adres IPv6 połączenia lokalnego: fe80::650b:2458:8755:b202%3 Serwery DNS IPv6: fec0:0:0:ffff::1%1 fec0:0:0:ffff::2%1 fec0:0:0:ffff::3%1 Producent: Realtek Semiconductor Corp. Opis: TP-Link Wireless USB Adapter Wersja sterownika: 1030.38.712.2019
am 30.04.2021 15:25
Hi Pablotto,
there is problem with the signal at the spot. To fix this, the owner of the conract has do contact us. Please use another spot instead.
Kind regards
am 30.04.2021 16:54
am 30.04.2021 17:59
Hi Pablotto,
there is no entitlement to the use of a particular spot. You can use it when you are on the move, not as a substitute for a fixed connection.
Kind regards
