am 23.07.2021 17:26
I tried to talk with a technician but it was not possible to do it in English. My router (Vodafone Station) is not conecting any Wifi device on 2,4Ghz, only on 5Ghz. I had to buy a Wifi extension to have connection on 2,4Ghz.
Every time i try to contact customer service they only send me to this channel. What can i do?
Thank you.
am 27.07.2021 15:12
i swapped the device, it should arrive you soon 🙂
Regards
am 24.07.2021 08:27
Hello Enrike,
which router do you have from us? In which state do you live?
Greetings Moni
am 24.07.2021 09:53
Hi.
I live in Berlin, and ghe router is a TG3442DE.
Thanks
am 24.07.2021 11:10
Hello Enrike,
I would be happy to take a look at the line. Please send me a PN with your customer data (name, address, customer number and date of birth).
Please contact me again when you have sent me the data.
Best regards
Moni
am 24.07.2021 11:25
Hi Moni,
I hope I managed to sent it.
Thanks.
am 24.07.2021 12:36
Hello Enrike,
currently both networks have the same SSID. Please assign an own one for each.
Greetings Moni
am 24.07.2021 12:46
Hi Moni
Thanks for the infor.ation. now is different names but rhe same problem. I also try to assigned a less occupied channel, removed the band steering, reset the router, and go on. But the 2.4Ghz is not working. I have only 3 device that they have not the 5Ghz and they cannot connect to the 2.4Ghz as i said since the beginning.
Thank you.
am 24.07.2021 15:28
Hello Enrike,
please reset the router completely and then use the data on the router.
Greetings Moni
am 24.07.2021 15:36
Hi Moni.
Thank you for your answer, as i said in the previous post i already tried. I just did it and it doesn't work. So i put again the password and ssd that i was using. But again the 2.4Ghz does not work. Only the 5Ghz. In case, as i said before, i already try to set up one channel that the saturation is lower, removed the brand steering, reset from factory the router, and go on. But still doesn't work.
Thanks.
am 26.07.2021 09:54
Hello Enrike,
then we can gladly exchange the device. Would that be okay for you?
Greetings Moni
