Menu Toggle
Aktuelle Einschränkungen:
Behoben! Mobil:  Einschränkungen Mobile Telefonie u. Daten 2G/4G im Bereich Bad Schandau, Dresden, Sebnitz
Kabel: Ankündigung Ausfall aufgrund von Wartungsarbeiten
Close announcement
Siehe neueste
WiFi disabled
d309254043
Hi, my kabelrouter disconnected from Internet about an hour. After that., i can use internet with wire but not the WiFi. The Kabel. box said my WiFi disabled. And i can't enable it. Anything i can do about this?
ERFD
Moderator
Hello d309254043,
please answer the following questions. We would like to have a look at it. Did you try to activate the WLAN connection via LAN using the GUI? Did you try power reset and factory reset?
Best regards Fred
Netz-Assistent How To Hilfe !
#bleibtgesund
