am 07.02.2021 10:33
ich habe seit einigen tagen ca 4% packetloss. Mein Router startet sich immer mal wieder neu. ich habe einen path ping laufen lassen und dabei ist aufgefallen, dass laut google ein Backbon mit der IP 145.254.3.100 bei euch 100% packetloss verursacht.
Computing statistics for 300 seconds... Source to Here This Node/Link Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address 0 my-pc.home [192.168.0.110] 0/ 100 = 0% | 1 2ms 0/ 100 = 0% 0/ 100 = 0% compalhub.home [192.168.0.1] 0/ 100 = 0% | 2 15ms 0/ 100 = 0% 0/ 100 = 0% ip53a9b747.static.kabel-deutschland.de [83.169.183.71] 0/ 100 = 0% | 3 16ms 0/ 100 = 0% 0/ 100 = 0% ip5886cadd.static.kabel-deutschland.de [88.134.202.221] 0/ 100 = 0% | 4 --- 100/ 100 =100% 100/ 100 =100% 145.254.3.100 0/ 100 = 0% | 5 18ms 0/ 100 = 0% 0/ 100 = 0% 145.254.2.175 0/ 100 = 0% | 6 17ms 0/ 100 = 0% 0/ 100 = 0% 72.14.195.160 0/ 100 = 0% | 7 19ms 0/ 100 = 0% 0/ 100 = 0% 108.170.247.103 0/ 100 = 0% | 8 18ms 0/ 100 = 0% 0/ 100 = 0% 172.253.72.249 0/ 100 = 0% | 9 29ms 0/ 100 = 0% 0/ 100 = 0% 216.239.48.145 0/ 100 = 0% | 10 28ms 0/ 100 = 0% 0/ 100 = 0% 74.125.242.225 0/ 100 = 0% | 11 27ms 0/ 100 = 0% 0/ 100 = 0% 216.239.35.185 0/ 100 = 0% | 12 26ms 0/ 100 = 0% 0/ 100 = 0% bud02s28-in-f14.1e100.net [172.217.20.14]
Ist das evtl. das Problem? Geschwindigkeit bei mir passt soweit.
am 08.02.2021 21:43
Es wird schlimmer...
Tracing route to bud02s28-in-f14.1e100.net [172.217.20.14]
over a maximum of 30 hops:
1 compalhub.home [192.168.0.1]
2 83-169-183-71-isp.superkabel.de [83.169.183.71]
3 ip5886cadd.static.kabel-deutschland.de [88.134.202.221]
4 145.254.3.100
5 145.254.2.175
6 72.14.195.160
7 108.170.247.103
8 172.253.72.249
9 216.239.48.145
10 74.125.242.225
11 216.239.35.185
12 bud02s28-in-f14.1e100.net [172.217.20.14]
4 145.254.3.100
5 145.254.2.175
6 72.14.195.160
7 108.170.247.103
8 172.253.72.249
9 216.239.48.145
10 74.125.242.225
11 216.239.35.185
0 gaming-pc.home [192.168.0.110]
0/ 100 = 0% |
1 1ms 0/ 100 = 0% 0/ 100 = 0% compalhub.home [192.168.0.1]
1/ 100 = 1% |
2 20ms 1/ 100 = 1% 0/ 100 = 0% 83-169-183-71-isp.superkabel.de [83.169.183.71]
0/ 100 = 0% |
3 20ms 4/ 100 = 4% 3/ 100 = 3% ip5886cadd.static.kabel-deutschland.de [88.134.202.221]
0/ 100 = 0% |
4 --- 100/ 100 =100% 99/ 100 = 99% 145.254.3.100
0/ 100 = 0% |
5 25ms 4/ 100 = 4% 3/ 100 = 3% 145.254.2.175
0/ 100 = 0% |
6 21ms 1/ 100 = 1% 0/ 100 = 0% 72.14.195.160
0/ 100 = 0% |
7 22ms 1/ 100 = 1% 0/ 100 = 0% 108.170.247.103
0/ 100 = 0% |
8 21ms 5/ 100 = 5% 4/ 100 = 4% 172.253.72.249
0/ 100 = 0% |
9 32ms 2/ 100 = 2% 1/ 100 = 1% 216.239.48.145
0/ 100 = 0% |
10 32ms 2/ 100 = 2% 1/ 100 = 1% 74.125.242.225
0/ 100 = 0% |
11 32ms 4/ 100 = 4% 3/ 100 = 3% 216.239.35.185
0/ 100 = 0% |
12 30ms 1/ 100 = 1% 0/ 100 = 0% bud02s28-in-f14.1e100.net [172.217.20.14]
Trace complete.
am 12.02.2021 15:04
Hallo rmbl,
wenn es auf dem Weg der Messung einen 100% Paketloss geben würde, dann würdest Du danach keinen Hop mehr erreichen.
Damit wir uns einen ersten Überblick verschaffen können, beantworte bitte einmal die offenen Fragen aus dem Link.
Viele Grüße, Martin
am 17.02.2021 15:01
Stimmt sind nur 99%. Steht ja auch in dem was ich gepostet habe. Macht's trotzdem nicht besser.
Hier die Daten:
tracert google.com Tracing route to google.com [2a00:1450:4001:810::200e] over a maximum of 30 hops: 1 2 ms 2 ms 2 ms compalhub.home [2a02:810d:4b40:3928:3a43:7dff:fe0e:b763] 2 12 ms 9 ms 11 ms 2a02:810d:1:96::1 3 24 ms 16 ms 25 ms 2a02:8100:6:2::10a:8b1 4 * * * Request timed out. 5 * * * Request timed out. 6 * * * Request timed out. 7 14 ms 14 ms 11 ms 2001:4860:1:1::2a4 8 18 ms * * 2001:4860:0:110c::8 9 20 ms 21 ms 19 ms 2001:4860::c:4001:5639 10 18 ms 20 ms 30 ms 2001:4860::8:0:cb93 11 20 ms * 22 ms 2001:4860::1:0:d0c6 12 29 ms 17 ms 17 ms 2001:4860:0:1::3167 13 21 ms 24 ms 18 ms fra16s50-in-x0e.1e100.net [2a00:1450:4001:810::200e] Trace complete.
Tracing route to ham02s13-in-f14.1e100.net [172.217.20.14] over a maximum of 30 hops: 0 gaming-pc.home [192.168.0.110] 1 compalhub.home [192.168.0.1] 2 ip53a9b747.static.kabel-deutschland.de [83.169.183.71] 3 ip5886caa9.static.kabel-deutschland.de [88.134.202.169] 4 145.254.3.102 5 145.254.2.181 6 72.14.195.160 7 74.125.244.82 8 108.170.233.59 9 142.250.46.110 10 74.125.242.225 11 216.239.35.185 12 ham02s13-in-f14.1e100.net [172.217.20.14] Computing statistics for 300 seconds... Source to Here This Node/Link Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address 0 gaming-pc.home [192.168.0.110] 0/ 100 = 0% | 1 1ms 0/ 100 = 0% 0/ 100 = 0% compalhub.home [192.168.0.1] 0/ 100 = 0% | 2 17ms 0/ 100 = 0% 0/ 100 = 0% ip53a9b747.static.kabel-deutschland.de [83.169.183.71] 0/ 100 = 0% | 3 18ms 0/ 100 = 0% 0/ 100 = 0% ip5886caa9.static.kabel-deutschland.de [88.134.202.169] 0/ 100 = 0% | 4 --- 100/ 100 =100% 100/ 100 =100% 145.254.3.102 0/ 100 = 0% | 5 20ms 0/ 100 = 0% 0/ 100 = 0% 145.254.2.181 0/ 100 = 0% | 6 19ms 0/ 100 = 0% 0/ 100 = 0% 72.14.195.160 0/ 100 = 0% | 7 20ms 0/ 100 = 0% 0/ 100 = 0% 74.125.244.82 0/ 100 = 0% | 8 --- 100/ 100 =100% 100/ 100 =100% 108.170.233.59 0/ 100 = 0% | 9 30ms 0/ 100 = 0% 0/ 100 = 0% 142.250.46.110 0/ 100 = 0% | 10 29ms 1/ 100 = 1% 1/ 100 = 1% 74.125.242.225 0/ 100 = 0% | 11 28ms 0/ 100 = 0% 0/ 100 = 0% 216.239.35.185 0/ 100 = 0% | 12 28ms 0/ 100 = 0% 0/ 100 = 0% ham02s13-in-f14.1e100.net [172.217.20.14] Trace complete. Tracing route to ham02s13-in-f14.1e100.net [172.217.20.14] over a maximum of 30 hops: 0 gaming-pc.home [192.168.0.110] 1 compalhub.home [192.168.0.1] 2 ip53a9b747.static.kabel-deutschland.de [83.169.183.71] 3 ip5886caa9.static.kabel-deutschland.de [88.134.202.169] 4 145.254.3.102 5 145.254.2.181 6 72.14.195.160 7 74.125.244.82 8 172.253.70.103 9 216.239.48.145 10 74.125.242.225 11 216.239.35.185 12 ham02s13-in-f14.1e100.net [172.217.20.14] Computing statistics for 300 seconds... Source to Here This Node/Link Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address 0 gaming-pc.home [192.168.0.110] 0/ 100 = 0% | 1 1ms 0/ 100 = 0% 0/ 100 = 0% compalhub.home [192.168.0.1] 0/ 100 = 0% | 2 16ms 0/ 100 = 0% 0/ 100 = 0% ip53a9b747.static.kabel-deutschland.de [83.169.183.71] 0/ 100 = 0% | 3 16ms 0/ 100 = 0% 0/ 100 = 0% ip5886caa9.static.kabel-deutschland.de [88.134.202.169] 0/ 100 = 0% | 4 --- 100/ 100 =100% 100/ 100 =100% 145.254.3.102 0/ 100 = 0% | 5 19ms 0/ 100 = 0% 0/ 100 = 0% 145.254.2.181 0/ 100 = 0% | 6 18ms 0/ 100 = 0% 0/ 100 = 0% 72.14.195.160 0/ 100 = 0% | 7 18ms 0/ 100 = 0% 0/ 100 = 0% 74.125.244.82 0/ 100 = 0% | 8 19ms 1/ 100 = 1% 1/ 100 = 1% 172.253.70.103 0/ 100 = 0% | 9 28ms 0/ 100 = 0% 0/ 100 = 0% 216.239.48.145 0/ 100 = 0% | 10 27ms 0/ 100 = 0% 0/ 100 = 0% 74.125.242.225 0/ 100 = 0% | 11 27ms 0/ 100 = 0% 0/ 100 = 0% 216.239.35.185 0/ 100 = 0% | 12 28ms 0/ 100 = 0% 0/ 100 = 0% ham02s13-in-f14.1e100.net [172.217.20.14] Trace complete.
am 19.02.2021 10:36
Hallo rmbl,
die Anfrage kommt bis zum Ziel durch, dort ist kein Fehler zu sehen. Startet der Router jeden Abend neu, ist das mehrmals am Abend der Fall? Wie sieht es mit einem anderen Koaxialkabel aus?
am 20.02.2021 09:59
Koaxial Kabel habe ich schon ausgetauscht gehabt. Daran liegt es nicht. Er startet immer mal wieder neu. Mag sein das Pakete durchkommen aber eben nicht zuverlässig.
am 23.02.2021 15:07
Hallo rmbl,
wann genau war der letzte selbstständige Routerneustart?
am 24.02.2021 09:30
Gerade eben hat der Router sich neugstartet. Ca. 9:25.
am 25.02.2021 15:11
die Pegel der Downstreams sind etwas niedrig und das möchte ich mir gerne genauer anschauen. Sende mir dazu Deine Kundendaten (Name, Anschrift, Kundennummer, Geburtstag) in einer privaten Nachricht und gib dann hier Bescheid, dass Du die Daten übermittelt hast.
VG Wallace
am 25.02.2021 19:46
Kundendaten habe ich die per PN geschickt.
