28.09.2021 23:04 - bearbeitet 28.09.2021 23:10
I have Red Internet & Phone 250 Cable contract since April. Download and upload speed were ok at the beginning. But the download speed is not stable and is not fast enough in recent weeks. You can find some results that were taken from speedtest.net below.
Morning hours: https://www.speedtest.net/result/12103070122
Afternoon: https://www.speedtest.net/result/12104640591
Evening: https://www.speedtest.net/result/12105460467
Night (around 10pm): https://www.speedtest.net/result/12105841884
More information:
I followed the steps on the help page here: https://kabel.vodafone.de/hilfe_und_service/stoerungshilfe . Even I reset the router. But none of them helped to fix the issue.
Do you think can the problem be solved somehow? Otherwise, it is meaningless to pay for 250 Mbit download speed for me.
am 19.12.2021 22:05
Thank you @Claudia,
I already canceled my contract. So, I don't need a technician anymore. It's already too late to see a solution from you (3 months as I said).
Best,
Enes.
am 01.10.2021 09:00
Hi EnesA,
thank you for the informations We will prove the connection. Please send me your name, address, day of birth and customer number by PN. Please also let me know here if you have sent the message.
Kind regards
am 01.10.2021 14:11
am 05.10.2021 08:26
Hello EnesA,
are you testing via LAN or WLAN?
Currently there is only one device connected to LAN 1 that can handle 100 MBit/s, is that your test device?
Greetings Moni
am 05.10.2021 21:15
Hello @Moni_GK ,
I tested the speed with both LAN and WLAN. The result is the same.
Normally my TV is connected to LAN 1. It is not the test device.
Here is another result that I took a few minutes ago.
am 07.10.2021 09:33
Hello EnesA,
the test was via LAN?
Currently it looks good. Is the speed permanently so low or only at certain times?
Greetings Moni
am 09.10.2021 19:42
am 12.10.2021 08:38
am 15.10.2021 22:07
Hi @Tobias,
Here is the test result with LAN at 22:00
https://www.speedtest.net/result/12190283472
As I said before, the connection I really good in the morning but unfortunately not at night.
am 18.10.2021 16:59
Hello EnesA,
The fault here is a return path interference. This is an interference signal on the line. My colleagues are on it.
I have recorded a ticket so that you will be informed about the completion of the fault. Unfortunately there is no info yet how long it will take.
Greetings Moni
