am 05.03.2019 10:09
Hello,
I am a new customer of Vodafone DSL and have a problem with the initial setup of my FRITZBox or the establishment of a DSL connection.
The supplied FRITZBox 7430 can not establish a DSL connection. Even after several reboots and reset to factory settings, the Power / DSL LED continues blinking.
DSL information
DSL diagnostics
I have tried everything that the FRITZBox error support and therefore checked the wiring several times.
What else I can try?
Thank you
am 05.03.2019 16:18
Hello Erdemt,
welcome to our community.
You say that you have a new DSL contract. Has the technician already been to your house to activate the DSL access?
BR,
Dany
am 05.03.2019 17:55
am 06.03.2019 13:34
Hi Erdemt,
ok, that sounds good. And you already configured your access with the modem installation code you received with our welcome letter?
BR,
Dany
am 06.03.2019 14:58
Yes I tried to configure my access with MIC but it resulted with the error below. Is it possible to create a ticket for this issue? I cannot contact to callcenter since I can't speak German well.
am 07.03.2019 16:46
Hello Erdemt,
did you check the cables already?
Because the technician was there an check the line, we only can send you a paid technician.
Best Regards
Sebastian
