am 03.04.2019 20:29 - zuletzt bearbeitet am 03.04.2019 21:03 von Grit
DSL - Fritz box 7430. Not able to restart internet after netzmodernisierung, i cant reach english speaking customer care executive.
I have new MIC but i cannot open fritz.box user interface and hence not able to set up new MIC.
Please help
Edit: Please stop creating new posts all the time, especially on the same topic. One post is enough, this one here, all others I have moved to the archive. In addition you should not send private messages to moderators, if you were not requested to it. One post is enough, this one here.
am 04.04.2019 10:28
Hi upmav,
please connect your laptop via LAN cable or WIFI with your modem und use this link to access the modem menu: http://fritz.box
Alternatively you can use http://192.168.178.1 or http://169.254.1.1
You now can start the assistant that helps you set up the modem.
If this does not work I need to kno where exactly you are having problems and if you see an error message etc.
Regards,
Jens
am 04.04.2019 17:19
