am 24.07.2017 11:53
Hello,
I got a DSL connection a couple of months back and the 2.4 Ghz suddenly stopped working and I am not able to see the SSID for the 2.4 Ghz band anymore. I am not able to connect my 2.4 Ghz compatible devices at all.
Kindly help.
am 27.07.2017 16:28
Hi Pradeep1,
have you made a reset?
Regads,
Norman
am 07.08.2017 14:27
No I have not attempted a reset.. I am not sure what will be consequences of it. Once I reset, Will I need the modem installation code again to set things up ?
Pradeep.
am 11.08.2017 15:28
Hi Pradeep1,
if you reset your Modem all data will be erased from it and you have to activate it again with your Modem-Installations-Code.
Regards,
Jens
