My Vodafone Easybox 804, 2.4 Ghz frequency not working
Pradeep1
Hello,
   I got a DSL connection a couple of months back and the 2.4 Ghz suddenly stopped working and I am not able to see the SSID for the 2.4 Ghz band anymore. I am not able to connect my 2.4 Ghz compatible devices at all.
Kindly help.
Norman
Community Manager
Community Manager
Hi Pradeep1,
have you made a reset?
Regads,
Norman
No I have not attempted a reset.. I am not sure what will be consequences of it. Once I reset, Will I need the modem installation code again to set things up ?
Pradeep.
Jens-K
Ex-Moderator:in
Ex-Moderator:in
Hi Pradeep1,
if you reset your Modem all data will be erased from it and you have to activate it again with your Modem-Installations-Code.
Regards,
Jens
