am 29.10.2019 08:09
Good morning,
I have a cable contract 500mbps and unlimited phone calls. The past week all my devices are getting disconnected every 5 seconds or so. I tried every possible reset, factory reset, disconnecting cables, run Malwarebytes , antivirus etc. Tested one device each time and all have the same issue. I logged into the router and apparently it sees my devices as potential threats and kicking them out. Main issue is Black list address and ddos attack. I tried calling service number but everyone is rude because I do not speak German. I think the router is defective. I am using the Vodafone router. Any solutions?
am 18.11.2019 20:42
am 19.11.2019 21:56
Hi Odenfoth,
please perform a factory reset on the router and check whether the disconnects still occur then.
Best regards Martin
am 19.11.2019 22:14
@Martin59 I just did it again and instantly after some seconds I connected I get disconnects again. I have to change to data in order to upload everything here... otherwise it will keep kicking me out@
am 20.11.2019 19:15
I tried hard resetting from the page and from the reset button on the hardware but the firmware doesn't downgrade like they say in other threads to the older 01.01 version. It stays at 01.02 etc is there another way to get that version manually installed to the router? Downgrade it myself? @Martin59 @Manu @Tobias @Claudia
am 20.11.2019 20:29
Hi Odenefoth,
Unfortunately you have no possibility to perform a manual downgrade.
What devices did you connect to the W-Lan?
Best regards Martin
am 20.11.2019 20:35
My phone and my laptop only.
am 20.11.2019 21:48
Hi Odenefoth,
we clarify again different things and announce ourselves then again.
Best regards Martin
am 20.11.2019 21:50
Ok.. I am gonna wait. Please inform me here what is the next step.
am 21.11.2019 14:33
Hi Odenefoth,
please run a ping plotter and send us a screenshot of the results.
Best regards Martin
am 22.11.2019 21:31
