Internet keeps dropping
Rodalben
This is in regards to my Kabel internet. Which is connected to my PC via ethernet cable.
Starting last night my modem/router combo started turning on and off. It will connect to the internet for about 5 to 10 minutes then turn off and the modem restarts and it keeps doing this. I tried a reboot and that didnt work. I tried unplugging for 2 to 5 minutes and that didnt work. I even did a factory reset and that didnt solve the issue.
I noticed when I get into the box settings that I have A LOT of uncorrectables in a couple channels.
Please help. I seem to have internet issues every 2 to 3 months and they are always different issues.
11 Antworten 11
Ex-Moderator:in
Ex-Moderator:in
hey,
i would like to send you a technician, some modem frequencies do not fit. do you send me a phone number where you can be reached via private message?
Regards
Rodalben
PM sent Tobias
pRo-Marco
Ex-Moderator:in
Ex-Moderator:in
Hi Rodalben,
the technician will call you to arrange an appointment
Please keep ud informed.
Kind regards
the technician came out and just checked the house box in my celler. Im still havbing horrible internet. tonight im sitting at 1.87 down and 6.9 up. when can i expect this to be fixed?
pRo-Marco
Ex-Moderator:in
Ex-Moderator:in
Hi Rodalben,
the signal is good now. Do you make the speedtests with WiFi?
Kind regards
No, all my tests are hardline via ethernet cable. the only devices in my house using wifi are my handys.
Moni_GK
Administrator:in
Administrator:in
Hello Rodalben,
is the connection everytime so bad or only at the evening?
Regards
Moni
My connection drops to about 1 to 4 MBps download and 20ish upload at around 1900
pRo-Marco
Ex-Moderator:in
Ex-Moderator:in
Hi Rodalben,
and befor 19:00 you get full speed?
Kind regards
