am 28.07.2018 11:43 - zuletzt bearbeitet am 28.07.2018 11:47 von Stephan
Last month the internet connection is very unstable.
Ping in online games goes very high periodically.
Dropping connection, so I have to reboot the router.
How can this be fixed?
Thank you in advance.
EDIT: @gaaarfild moved to cable section
am 09.08.2018 13:35
Hi Claudia,
I tried to switch the channels. Also tried 2.4GHz and 5GHz.
Unfortunately - no changes. 😞
Kindest regards,
Dinar.
am 13.08.2018 10:09
Hi Dinar,
can you please take the networkcable, which was delivered with your device and check if there are any issues? Maybe you can take your Laptop or computer to your router for testing.
The router ist online about 5 days and everything ist fine. No signal variability or anything else.
Best Regards, Manu
am 21.02.2019 00:02
Hello again. Seems like that problem is solved. Via cable I don't see any problems. But now Another issue with game Apex Legends. I'm periodically getting network freezes. I ran PingPlotter.
As I couldn't attach it to this post, i posted it to the dropbox.
https://www.dropbox.com/s/8oas1vwgnqcgdw5/146.148.120.92.pp2?dl=0
Could you please check why it happens?
Kindest regards,
Dinar.
am 24.02.2019 09:28
Hello gaaarfild,
we don't open pp2 files. Please insert it as a picture. About a screenshot.
Best regards Fred
am 24.02.2019 18:43
am 26.02.2019 21:35
Hello gaaarfild,
the test is perfectly fine. Apparently there are a lot of packet losses from your device to the Fritz!box.
Best regards Fred
am 26.02.2019 21:55
Hi Fred,
I don't have a Frtizbox. I think it's a Kabelrouter. The big black dual-band one.
Packet loss is a problem of a router or something else?
Kind regards,
Dinar.
am 28.02.2019 15:29
Hello gaaarfild,
that is measured again with LAN or with WLAN?
Do you have problems only to the page or to all pages?
Best regards
Moni^mmk
am 28.02.2019 15:34
I now always use LAN (Ethernet) only.
And this problem happens to me in Apex Legends game and also in Overwatch.
Random internet lags lasting 10-15 seconds and causing disconnects.
am 04.03.2019 07:53
Hello gaaarfild,
you can test if the packet losses disappear with another Lan cable or if necessary change your NIC once from 1000 MBit to 100 MBit. Maybe this will do something. Do you have the same problems with another PC/MAC via LAN?
Best regards Fred
