Internet doesn't work.. DOCSIS offline
shmj614
Youngster
Youngster
Dear sir,
I've recently contracted Internet with Vodafon and installed router yesterday (Customer number: ***)
But Internet still doesn't work and flashes red light on the router...
I've tried to check with IP address and it says DOCSIS offline.
Please kindly check this problem asap, as it is pretty urgent for me...
Kind regards,
MJ
@shmj614 Customer number removed and contribution moved from DSL to cable. Please do not post private data public. VG_Grit
7 Antworten 7
Ex-Moderator:in
Ex-Moderator:in
Hello shmj614,
I'd like to check this. Please send me your details (customer number, address, date of birth and MAC address of the modem) in a private message. Reply here again afterwards.
Kind regards,
Dear Claudia,
Could you check your privite message?
MJ
Ex-Moderator:in
Ex-Moderator:in
Hello minjeeshin,
you forgot to send your customer number. Please send it another private message and reply here again.
Kind regards,
I've just sent you my customer number.
plz check another privite msg.
Ex-Moderator:in
Ex-Moderator:in
Hello minjeeshin,
thank you. The installation didn't finish properly, so a technician needs to come to you. I made a task for that, so you should receive a call in the next few days for the appointment.
Kind regards,
Can you help to me, i have the same problem?
Ex-Moderator:in
Ex-Moderator:in
Hello Anaguarana,
please open an own thread for that but remember not to post your private data in public. I will close this thread now.
Kind regards
