am 24.08.2019 11:23
I am hoping that someone can help me with an issue that I'm having with my Internet connection (Kabel Internet). The WLAN connection between the router and our devices (iPhones, computers) is consistently working. However, the connection from the router to the Internet keeps dropping. When I power-off and then power-on the router, the Internet connection will reconnect and work for about 5-15 minutes, and then the connection to the Internet disconnects again. It does not reconnect unless I power-off and then power-on the router. I have done this procedure many times and get the same result, that the Internet connection disconnects after 5-15 minutes. If anyone is able to help me, I would very much appreciate it. Thank you! Tom
am 26.08.2019 11:54
Hello, TRB,
I'd love to check out your connection. Please send me your customer number, address and date of birth by private message.
Write me here briefly, if you have sent the data.
Does the problem also occur via LAN? Has the WLAN configuration been checked and optimized?
https://www.vodafone.de/hilfe/wlan-hilfe-beim-einrichten.html
Best regards Fred
am 03.09.2019 09:43
Hello, TRB,
thank you for your answer. Nice that it runs better now in the other floor 🙂 Yes, the support is not obliged to speak English. I believe that this is difficult as a beginner.
If you don't have any questions, we are there for you.
Best regards Fred
