am 13.06.2019 17:16 - zuletzt bearbeitet am 13.06.2019 17:51 von HeikeF
The ping is slow and also losing data, basic it is very slow to answer and the internet flutuate a lot.
Picture attached with ping Vodafone and Google, the time = should be below 10ms always.
My router is Vodafone TG3442DE
Customer number xxx is under my wife name. Please reply if need address and her full name.
Tks, Andre
Edit: Please don´t post your customer number here open to the public
am 14.06.2019 10:38
Hello andrenvillela,
please send a Pingplotter or tracert screenshot, not a simple ping that doesn't show where the rise is. Make sure to use a direct ethernet connection. Are all destinations at each time of the day affected?
Kind regards
am 14.06.2019 11:07
I am attaching few tests I did on cable.
It is unstable the whole day in all destinations.
I am attaching several tests but you can see on the TRACEROUTE on TERMINAL that several packets are lost, it is very unstable, that way feel like very slow internet when in fact it is fast as you see on the other tests but unstable what make it worst.
am 14.06.2019 15:31
okay, I would like to have a look at your access. Please send me a private message that includes your address, birth date and customer number. Answer again in this thread when you sent the PM.
Kind regards,
am 14.06.2019 16:42
Hi Claudia, I just sent you the PM
am 17.06.2019 18:11
there is a problem with the utilisation of the line, which sometimes starts to rise around noon. The line needs to be expanded, I made a fault report for you and assigned it to the line upgrade task. You will get an e mail as soon as the expansion is finished.
Kind regards
am 28.06.2019 15:05
Hi Claudia, would you have any feedback on the internet ?
am 30.06.2019 14:16
Hi andrenvillela,
the expansion should be completed in December
Kind regards
am 25.10.2019 11:31
The internet now is not instable, it is not working most of the time since the morning on 25-OCT-2019 !!!
Need assistance ASAP... I work from home !
am 28.10.2019 15:21
Hi andrenvillela,
please stop samming via PM. You will get no reply, because we do not answer, if we did not ask for the message.
The modem often looses connection to our infrastructure. I'd like to send a technician atyour place. Is that okay for you? We need access to the technical room where the signal is distributed. Is that possible?
Kind regards
