Menu Toggle
Aktuelle Eilmeldungen:
eSIM: Einsicht in eSim Daten (QR-Code, ePin) in MeinVodafone-App und Mein Vodafone Web
MeinVodafone-App: Self-Service Vertrag- und Tarifoptionen
Mobile Telefonie und Daten 2G/3G/4G PLZ Gebiet 073xx, 079xx, 08538, 951xx, 96367
Close announcement
Siehe neueste
Internet Outages Multiple Times
Highlighted
Hello. To start an apology: I am learning German but it is not good enough for me to describe the issue here.
Multiple times today my internet has gone offline for minutes at a time. It starts with an internet freeze, then the Wireless Network and Wired Network goes offline, and then the Router Reboots. All the while, the internet icon flashes red.
It seems my router is shutting down and starting again multiple times.
The support line states that my connection is normal and that there are no issues, but my experiences so far show otherwise. What should I do?
Highlighted
Moderatorin
Hello JohnTriaged,
which federal state do you live in and what router do you use? Have you tried to restart the device and replace the coaxial cable?
Kind regards
Alles Easy How To Hilfe !
